Big Power Vxt Project
4722 replies to this topic
#2541 siztenboots
  • 26,611 posts
Posted 13 March 2015 - 03:00 PM
http://www.vx220.org...etup/?p=1241530
#2542 Nev
Posted 13 March 2015 - 03:07 PM
Thankyou, seems the Porche units are heavier, oh well.
#2543 The Batman
Posted 13 March 2015 - 03:49 PM
Perfect for a turbo :P
#2544 Nev
Posted 13 March 2015 - 05:07 PM
Poor Nipper will be approaching 950 KG if I don't watch out :(
#2545 The Batman
Posted 13 March 2015 - 05:18 PM
Wow! It's a good thing you have a lot of power lol
#2546 Nev
Posted 20 March 2015 - 03:04 PM
Nipped out on some familiar country roads this afternoon for the first time since the remap. The smilies say it better than words:   :wacko:  :o  :wacko:  :tt:
Edited by Nev, 20 March 2015 - 03:13 PM.
#2547 CocoPops
CocoPops
  • 17,180 posts
Posted 20 March 2015 - 03:08 PM
It's also the worst kind of weight isn't it? Unsprung weight? Might be bs but I'm sure I read somewhere that for every 1kg of unsprung weight removed, it's equivalent to 4kg of sprung weight removed? For handling benefits that is, not weight reduction overall.
#2548 Nev
Posted 20 March 2015 - 03:17 PM
Yes I'm sure it must have some effect, though in the real world I think stopping approx. 30% faster is more important than adding a couple demi-seconds to rebound rates. Just looking at big fat cars like Porsches, Audis and BMW 5s etc, which have seemingly high floating masses, they all seem to handle adequately.
Having said that, the projected cost of building this brake kit has crept a lot, so I am undecided whether to go ahead ATM, so the extra KG per corner may never materialise.
Edited by Nev, 20 March 2015 - 03:22 PM.
#2549 Nev
Posted 27 March 2015 - 04:19 PM
Some research has gleaned that the Alfa Romeo 159 has a 345mm by 28.5mm disc to fit the exact same 65.1mm 5x110 pcd hub as the VX, so I bought one for £15 off eBay.
2 hours in the garage this afternoon and I offered up the Alfa disc to the Elise Part upright with the Brembo calipers:
Doesn't look too huge in the 18" wheels:
At least 1" of clearance between wheel and caliper thanks to my 18" wheels:
Everything seems to fit, but with 1 technical decision about spacers to be made; I will review this with Josh to see if he concurs with me. All in all this really cheap solution is looking good at the moment though.
I have done the calcs and this setup will be +4 KG per corner when compared to OEM brakes. This isn't great news for rebound rates and nimbleness, but hopefully will be positively offset by epic braking that Nipper sorely needs.
Edited by Nev, 27 March 2015 - 04:39 PM.
#2550 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,510 posts
    "Yes, I built it"
Posted 27 March 2015 - 05:26 PM
At this rate you will need more BHP to cope with all the extra weight  :P
Looks great, cant wait to hear what you think of them under use
#2551 Nev
Posted 27 March 2015 - 05:37 PM
At this rate you will need more BHP to cope with all the extra weight  :P   Looks great, cant wait to hear what you think of them under use
Hopefully they will be manage around -2.0g once the bias valve is installed.
#2552 Ormes
Ormes
  • 4,612 posts
Posted 27 March 2015 - 06:50 PM
Nice to see the positive update thumbsup See you both soon :)
#2553 Nev
Posted 27 March 2015 - 07:29 PM
The extra weight over the front should help reduce the wheelie effect ;)
#2554 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,792 posts
  • Interests:Big baps.
Posted 28 March 2015 - 07:57 AM
Would a 17" fit over them then, or is that taking margins too far?
#2555 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 28 March 2015 - 08:22 AM
I would've thought so. Working on that there's 1" gap a 17" wheel should in theory only half the gap? I may be wrong but it works out in my head :lol:
#2556 Nev
Posted 28 March 2015 - 09:12 AM
Yep as MopeyT says, for sure a 17" wheel would fit, maybe even a 16" wheel too. One of the reasons I chose the Porsche Brembos was because they have a very low mounting profile. For example the similar Alfa Brembo calliper mounting bolts stick out approx. 1cm proud of the casting, a design flaw that the Porsche ones don't have for some reason. I have written up a more in depth explanation of the engineering behind this mod on my website here: https://sites.google.../07---update-29
Edited by Nev, 28 March 2015 - 09:26 AM.
#2557 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,792 posts
Posted 28 March 2015 - 09:48 AM
The only think is it looks really wierd to see 'Porsche' written on parts of a VX.
#2558 Nev
Posted 28 March 2015 - 10:05 AM
Yea, I might stick a Vauxhall Griffon on them (with pride!).
#2559 TFD
TFD
  • 607 posts
Posted 28 March 2015 - 11:04 AM
Looks really good mate, great work there  thumbsup
#2560 Nev
Posted 28 March 2015 - 05:40 PM
After years of putting up with rattling doors I've finally splashed out £20 on some anti-rattle door pins - hoorah. Can't wait for them to arrive. Am getting an irrirating exhaust leak sound from the turbo/exh manifold area, I think it's likely to be the annoying T3 turbo flange stainless steel gasket melting again. I was supposed to tackle replacing it today (which is a 2 hour job), but had a bad case of "just can't be arsed" this afternoon :(
Edited by Nev, 28 March 2015 - 05:45 PM.
