Yes, I have the 12v vacuum pump in still, but it is getting tired now and only make 650 mBar of vacuum. I have a pressure guage plummed into the vac pipe just before the servo so know that the one way valve near the TB is working, as the vacuum is nicely sustained after switching the engine off. I wonder is my servo itself is not working 100%. It has to be that or the master cylinder. Or maybe I am just expected too much retardation, but seeing as I can't lock the wheels up or even trigger the ABS after about 60 MPH this is unlikely.
Hi Nev, one thing to note, if you want a quieter pump... the Fiat 500 seems to be able to provide assisted braking when start/stop is enabled and rolling down hills etc., with the engine off. I have no idea how they solved this but it certainly doesn't make a sound whatever it is!
