Edited by Nev, 15 February 2011 - 07:55 PM.
Big Power Vxt Project
#261
Posted 15 February 2011 - 07:51 PM
#262
Posted 15 February 2011 - 08:16 PM
Why are people so obsessed with how their engine bay looks, surely there are more substancial things you can do with your time.
#263
Posted 15 February 2011 - 08:29 PM
Here's one to haunt you for the rest of time.
Too much forum knowledge Matt!
#264
Posted 15 February 2011 - 09:17 PM
#265
Posted 15 February 2011 - 09:24 PM
#266
Posted 15 February 2011 - 09:26 PM
#267
Posted 15 February 2011 - 09:33 PM
#268
Posted 15 February 2011 - 09:42 PM
#269
Posted 16 February 2011 - 06:08 AM
#270
Posted 16 February 2011 - 10:56 AM
#271
Posted 16 February 2011 - 12:31 PM
#272
Posted 16 February 2011 - 12:34 PM
#273
Posted 16 February 2011 - 12:37 PM
#274
Posted 16 February 2011 - 01:25 PM
#275
Posted 16 February 2011 - 01:29 PM
Thats a good idea Steve, do you know which contacts I need to put a volt meter accross? I dont want to short circuit it as they cost £150+
At the moment I think I am going to run the engine in with the Astra VXR MAF (which the ECU is already calibrated to). Then I'll get it mapped and if we think the MAF is causeing a resistance, I may either buy the 92mm Audi S4 one or build my own 80mm I/D MAF from a piece of pipe and the sensor unit out of a standard OEM 70mm MAF.
i can read all that info on my scanguage as its not a linear thing, the ecu has a correction table which you get with a remap for the 80mm MAF upgrade. It would be a 5 minute TB swap to compare on mine if the 63mm benefits flow. For a custom MAF tube, you need to know the cross-section area to get the fuelling correct.
#276
Posted 16 February 2011 - 01:33 PM
#277
Posted 16 February 2011 - 01:39 PM
(the interface depicted here translated lb/min in a wrong way, picture is just for illustrating the OBD reader)
Measuring the voltage will not be the best way to compare the TBs. And just in case you happen to have some 300HP and still the 70mm MAF sensor built in you will simply read some 4.7V with full throttle because it clips. That's why every Z20 engine with a power of 280+ should have the 80mm MAF. Gives much better throttle response because of the sensor not clipping at all.
Edited by cs_, 16 February 2011 - 01:45 PM.
#278
Posted 16 February 2011 - 01:44 PM
I can't read the MAF on mine. Is there a manual code?
#279
Posted 16 February 2011 - 01:49 PM
Edited by Nev, 16 February 2011 - 01:51 PM.
#280
Posted 16 February 2011 - 02:09 PM
For four years I considered that as a normal thing, not an issue. Until I swapped to 80mm MAF last spring and remapped the lookup table in the engine ECU. After the upgrade to 80mm my throttle acted completely different, giving a linear 0-100% response, more down, more power, the whole way. The engine now acts more like a big N/A and less aggressive. The car is not slower, develops the same power, but less nervous. The engines is much more controllable now. Almost a brand new car, much more driving pleasure.
Discussing this topic with some mates in the german forum one came with actual measurements of the MAF voltage. And see, the 70mm MAF clipped at overboost. The 80mm doesn't. The opinion of the tuners seem to differ, the one which made my engine neglects that the 70mm MAF may clip, Klasen I heard says you need 80mm for 280HP or more. So I decided to rely on my own results. They tell me clipping is real with 70mm MAF. And is now gone for me.
The OBD PIDs are to be found in the web. For instance on Wikipedia. These are standard data words. Not Vauxhall specific.
7 user(s) are reading this topic
Bing (2)
