Big Power Vxt Project
4722 replies to this topic
#2941 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 12 April 2016 - 03:22 PM
Nev, i realy hope i can meet you one time.... Your car is a true inspiration for me. Also a passengerdrive would be nice to see the powerdelivery etc....
I can honestly tell having met Nev a few times he's a thoroughly nice chap and having been in his car it's only slightly fast ;)
#2942 Nev
Posted 12 April 2016 - 05:45 PM
Thank guys, nice of you to say so.
BTW Al, I've just stuck those softer springs you kindly sold me for a bargain on the rear of the car just now. Can't wait to go out for a test drive once the traffic dies down.
So I now have 350 front and 450 rear with the front ARB supposedly on 165 ft/lb of torque to stiffen up the front on a corner. I've reset the ride heights, but I expect it will all sag a bit over the next week.
Edited by Nev, 12 April 2016 - 05:49 PM.
#2943 siztenboots
  • 26,611 posts
Posted 12 April 2016 - 05:56 PM
mind the back will squat down and the front will rise up going a bit light on the steering
#2944 Nev
Posted 12 April 2016 - 06:18 PM
Yup, but with the lower spring rates I'm hoping to be able to set the rebound rate up a few clicks on the rear and maybe 1 or 2 on the fronts. Bear in mind my power comes in more softly than a stage 4, so it doesn't unbalance the axles too badly.
What coilovers + spring poundage have you got on yours BTW?
Edited by Nev, 12 April 2016 - 06:21 PM.
#2945 Ali87
Ali87
  • 1,287 posts
Posted 13 April 2016 - 05:10 PM
Jings, you might need a roof box for the Hoon!
#2946 Nev
Posted 13 April 2016 - 05:39 PM
The softer rear end is really nice, it was deffo a good idea to reduce the spring poundage for the types of road I drive on. Not sure what high speed feel will be like yet.
#2947 smiley
Posted 13 April 2016 - 05:42 PM
And a new header tank.
#2948 Ormes
Ormes
  • 4,612 posts
Posted 13 April 2016 - 05:43 PM
Nev that expansion tank is ripe for failure... get a spare from Vaux for when it goes ;)
#2949 Ormes
Ormes
  • 4,612 posts
Posted 13 April 2016 - 05:44 PM
FFS that is rather freaky timing thumbsup :)
#2950 Nev
Posted 13 April 2016 - 05:47 PM
I can't believe it, but my new alternator belt is squeaking again, probably as my old clamping bolts are tired and slipping on the bracket.
So I have ordered up a rose jointed adjustable threaded bar spacer that some kind engineer has made and offers on eBay. Quite a bargain really, he can't be making much money on it, but I will be thankfull all the same if I can stop the irritating noise.
I also did a 1400 mile oil change today. I've been noticing some positive things about the engine in the last 6 weeks or so, the oil smells less "petrolly" and also the magnetic sump plug had almost no fur on it. Also I am finding that I am only needing to top up maybe 500 milli litres of oil every 1000 miles. That's welcome news in the garage, and perhaps shows my policy of using mineral oil and changing it regularily is working out nicely for the bores & rings. If this continues, it will be tempting to move up to a B4 semi synth.
Edited by Nev, 13 April 2016 - 05:59 PM.
#2951 The Batman
Posted 13 April 2016 - 05:50 PM
nev that is a minging header tank you pikey :lol:
#2952 Nev
Posted 13 April 2016 - 05:52 PM
Yea, the engine bay is dreadfully dusty, partly due to lack of floorpan. I guess that thats what happens when you actually drive your car hard and dont treat it like a garage queen ;)
Last weekend I went through a dusty section of road with Hairy behind me at some considerable speed. It's no exadjurating to say that Nipper picked up so much dust that I really could not see him in the vortexes behind me - at all. It was quite incredible.
Edited by Nev, 13 April 2016 - 05:55 PM.
#2953 The Batman
Posted 13 April 2016 - 05:55 PM
When you actually drive your car hard
Too much information nev!!!!!!!
#2954 Nev
Posted 13 April 2016 - 05:56 PM
Ah yes, well spotted, I have noticed the yellowing of the header tank recently, maybe I should pre-emptively order another.
Is the water header tank for the NA the same as the VXT? The ones on eBay seem to have brass insert in the pipes, seems different to my current one. Maybe a new manufacturer?
Edited by Nev, 13 April 2016 - 06:07 PM.
#2955 siztenboots
  • 26,611 posts
Posted 13 April 2016 - 06:08 PM
500f / 600r , plus the helpers which I can't remember
today was spent at the dyno , made some very good numbers with the next generation VX software.
#2956 Nev
Posted 13 April 2016 - 06:10 PM
Jesus, 500f with a 1" ARB! Don't you struggle on bumpy roads?
Keen to see the dyno plots, post em up :) Are you able to kill the spool up torque spike that Klassen never did or is it impossible?
Edited by Nev, 13 April 2016 - 06:12 PM.
#2957 CHILL Gone DUTCH
Posted 13 April 2016 - 06:17 PM
I run 750/ 600 springs 350/250 helpers And are very compliant on the road with quantums Also with a 1" ARB
Edited by CHILL Gone DUTCH, 13 April 2016 - 06:18 PM.
#2958 Duncan VXR
Duncan VXR
  • 5,277 posts
Posted 13 April 2016 - 06:24 PM
N/a 2 port turbo 3 as it has extra outlet for turbo water return All oem has brass inserts for ref Nev you pikey do some basic maintenance 😉 and sort that boot / air box setup it hurts my eyes Def another vote for use and abuse your cars 😊 DG
#2959 Nev
Posted 13 April 2016 - 07:01 PM
The car has been getting a bits spluttery higher up the rev range in the last year and it has occured to me that the spark plugs are probably 6 or 7 years old now and probably due for a swap.
So I have just inspected them to see how they are fareing and they all look fine with a good colour, no visible ceramic cracks etc. I was hoping they might be a bit sooty on the tips which would have allowed me to drop a heat rating (currently on 9) which would make the car a bit better behaved when cold. But they are not, so I guess I will have to stick with "9"s, which although poor when cold at least minimise my risk of them overheating and breaking with the horrible conseqences of bits of metal and ceramic bouncing around on the pistons.
#2960 Nev
Posted 13 April 2016 - 07:05 PM
I'd have to have a drive to believe that, are the dampers clicked up a fair bit from minimum damping?
Makes me wonder about the valving in my Nitrons, the difference (increase in compression/rebound) in the click settings is really accute on mine and hard to have any fine control.
Edited by Nev, 13 April 2016 - 07:16 PM.
