Big Power Vxt Project
4722 replies to this topic
#3101 Nev
Posted 03 July 2016 - 09:51 AM
What kind of temps do you think your exhaust is withstanding around the turbo part
Hard to guesstimate really, the best way would be to insert a tiny pyrometer in there, which I did consider doing when I built it all up 7 years ago, but I didn't want the risk of it cracking and dropping into the turbo (with dire consequences).
The map is pretty rich (11.0:1 in places), but basically you have the equivalent heat of 500 electric bar heaters passing though this tiny 1" x 2" restriction at 24 PSI. The problem is exacerbated by taking already super hot gases and then compressing them and possibly causing them to get even hotter as per combined gas laws calcs. Then against this you have to offset the radiated heat loss, basically all too complicated for me to work out.
If I had to guess, maybe 950 to 1000 degree C when at full chat perhaps. It's certainly enough to melt and fuse the glass strand heat wrap on it - I only needed to tap it with a hammer to break it off the manifold in places.
Edited by Nev, 03 July 2016 - 09:59 AM.
#3102 CHILL Gone DUTCH
Posted 03 July 2016 - 10:29 AM
I also thing my sc exhaust is reaching in access of 850 degrees
#3103 Nev
Posted 03 July 2016 - 11:38 AM
I wouldn't be surprised if the gas exiting your cylinder head is more than that, but as soon as it can expand in the downpipe and exhaust it cools off surprisingly fast.
#3104 smiley
Posted 03 July 2016 - 11:41 AM
One of the germans measured near 1000.
But that was just after the cilinder head.
#3105 CHILL Gone DUTCH
Posted 03 July 2016 - 11:43 AM
One of the germans measured near 1000. But that was just after the cilinder head.
Is this on a sc spec car ?
#3106 redvts
redvts
  • 1,472 posts
Posted 03 July 2016 - 12:12 PM
thermal imaging camera?
Edited by redvts, 03 July 2016 - 12:13 PM.
#3107 chris_uk
Posted 03 July 2016 - 12:16 PM
is it glowing?
#3108 CHILL Gone DUTCH
Posted 03 July 2016 - 12:18 PM
  is it glowing?
I don't know I'm normally driving the car Might try and set a camera up on it to see But I may have to wrap my exhaust as its starting to discolour the subframe and
#3109 chris_uk
Posted 03 July 2016 - 12:20 PM
best getting a thermal gun  thingie and pointing it at the manifold when it comes in, just to get an idea.
#3110 CHILL Gone DUTCH
Posted 03 July 2016 - 12:25 PM
I might try a tape the gun trigger on and set up a camera on the gun & exhaust Lol
#3111 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 03 July 2016 - 12:38 PM
  is it glowing?
Very likely it will be before I wrapped mine, during the emissions test on MoT last year mine was glowing
#3112 stu8v
stu8v
  • 745 posts
Posted 03 July 2016 - 12:44 PM
My guess is its a 304 grade stainless. Not really the ideal grade for turbo application, that coupled to insufficient bracing. Normally it's a case of going thicker wall or more expensive material inconel or such.
#3113 CHILL Gone DUTCH
Posted 03 July 2016 - 12:50 PM
I think mine is 307 grade not 100% as I know very little about grades of SS Does 307 sound right ?
#3114 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
Posted 03 July 2016 - 12:54 PM
308 I imagine? I'm sure they're 304, 308 and 316?... I might be wrong though
#3115 TFD
TFD
  • 607 posts
Posted 03 July 2016 - 01:08 PM
SS Grades normally implies the way they withstand corrosion as what I was told. 316 for more corrosion/salty conditions, 304 for the rest.
Exhaust gasses are normally 800-900C. 1000C sounds as not great, get your EGT's down. The cast iron exhaust housings of turbo tend to glow red when on full temp.... that hot.
Why do you run AFR 11:1 ? Did you monitior your EGT's?
#3116 TFD
TFD
  • 607 posts
Posted 03 July 2016 - 01:09 PM
Edit.
Edited by TFD, 03 July 2016 - 01:10 PM.
#3117 stu8v
stu8v
  • 745 posts
Posted 03 July 2016 - 01:24 PM
304 is common general grade of which most use as it's cheap.
#3118 Arno
Arno
  • 1,238 posts
Posted 03 July 2016 - 01:33 PM
Peculiar crack, especially as the big flange went which is not something you usually see on tubular exhaust manifolds like these. Usually it will crack in/along the welds and likes to go onto the thinner wall sections like the pipes.
Might be able to have it cut/groove all the cracked sections out and then weld it back up. Then afterwards have the flange sanded flat again.
Might still distort/warp the position of the wastegate connnection but that's simply the risk of any repairs like these...
304/316 for manifolds is OK'ish, but not too great. Heat cracking is simply one of the things that will occur to it as the material is not really rated for these service temperatures (AFAIK it's only rated for sustained temperatures up to 300C)  and accelerated crack development is one of the issues. Especially in turbo manifolds with the extra heat and pressure before the turbo they will degrade and fail over some time and must really be seen a little as 'consumable'
An Inconel 625 based one would have a much longer lifespan as it is rated for these operating temps seen in a turbo manifold, but the material is much, much more expensive so it's a bit of an economic tradeoff between X cheaper stainless 304 manifolds vs. 1 inconel one and at what amount of 'X' the inconel one becomes interesting.
#3119 stu8v
stu8v
  • 745 posts
Posted 03 July 2016 - 01:46 PM
I know of folk using homemade SCH40 Carbon steel tubular manifolds with no issue. That many trackday miles too. Worth a thought if you're looking into making another. At the very least I'd cut that flange off and make another if you must re use your manifold. Given the work involved it's no more trouble imho.
#3120 CHILL Gone DUTCH
Posted 03 July 2016 - 01:57 PM
Who is running 11:1
10 user(s) are reading this topic
0 members, 10 guests, 0 anonymous users
