Big Power Vxt Project
4728 replies to this topic
#3161 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 10 July 2016 - 10:55 AM
Of course if I did post it to him, it might mysteriously "disappear" once in his hands and then he'd suddenly become "hard to get hold of" and it would probably take a court case to get him to replace it under the warrantee. Also, in this situation I would then not even have the manifold in my hands to put back on to limp the car to an exhaust place to have a new one fitted to a modified downpipe - a situation I don't want to find myself in. Basically we've all unfortunately met these people who don't honour their guarantees and throw as many hurdles for you jump over just to get them to do the right thing.
Anyway, DO NOT BUY FROM NORTECH PERFORMANCE.
Sad and angry Nev.
Bit harsh Nev when two pages ago you were singing their praises.
#3162 fiveoclock
fiveoclock
  • 9,453 posts
Posted 10 July 2016 - 11:01 AM
So called motorsport use (which is an almost meaningless statement) would be a harder environment for it, yet it can't cope with normal road use. ie if it cant cope with road use heat, then it would also fail with "motorsport" use heat. In other words both would have made it fail.   Anyway, I'm not going to argue the toss with you people, some of you have nasty chips on your shoulders and always react with negativity and lack of logic. What counts for me anyway is that the matter is in hand.
Of course motorsport use only isn't a meaningless statement. It means only use it for motorsport. It's not a hard concept to grasp. Motorsport, usually meaning relatively short periods of extreme use not longer periods of less extreme use as in road use. No point in getting the hump with other people and chucking your toys out of your pram. You were the one who chose to use it in the wrong manner.
#3163 vocky
Posted 10 July 2016 - 12:27 PM
my personal take on 'Motorsport use only' is that it means that is was designed for race use - thus should be removed and inspected after each race, so basically sod off if it breaks :(
Even if I stripped it down and inspected it every time I drove it (which is wholely unrealistic) it wouldn't change the fact that it still broke along a manufacturing weld (i.e. a manufacturing fault).
Some of you seem to be completely missing the key points. It was warranted, it broke, it should be fixed/replaced.
I am with you on this Nev, but the old saying goes 'warranties are not worth the paper they are written on'
#3164 Nev
Posted 10 July 2016 - 12:38 PM
Sadly, lack of culpability and any sort of ability for customers to easily and quickly redress with these people means they get away with it. However, in the long run I think word gets out and people stop buying from them. I went and checked on MIGWEB yesterday, and realise quite a lot people have had a bad response from him.
This is why place like Pro-Alloy are great, they actually care. People respond positively to them when they actually get meaningful and positive customer response.
Edited by Nev, 10 July 2016 - 12:41 PM.
#3165 Nev
Posted 10 July 2016 - 12:54 PM
Sad and angry Nev.
I heard from a few people in the past they thought he was great - this was when I bought the thing approx 6 years ago. Developments in the last few days in this instance shows that he has no desire to uphold the warantee. Hence I have changed my mind based on the actual bad experience I've had - not so hard to understand someone changing their mind based is it?
It's important to eek these bad eggs out IMO, and warn other potential buyers. If you think that is harsh of me, I disagree.
Edited by Nev, 10 July 2016 - 12:58 PM.
#3166 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 10 July 2016 - 01:35 PM
Read through all of this and I wish you luck with your crusade against them.
The only thing that really stood out for me since you first mentioned it was the erroneous spelling of 'warranty'. Maybe I have autism.
#3167 Nev
Posted 10 July 2016 - 04:39 PM
Ooops, it seems I need a spelling lesson!
#3168 Nev
Posted 13 July 2016 - 08:43 PM
Got the stuck bolt out, pre-heated the weld + flange to red with blow torches to try and de-stress it and then skimmed the flange.
I don't have huge hopes to the repair, if it cracks on the flange again the intention is to approach the problem in a different way next time. Fingers crossed.
Here are the pics before and after the flange was skimmed:
Feeling ill with man flue ATM, will stick it back in the car when I feel better. Will try and heat cycle it mildly a few times in the hope the metal can de-stress from the welding.
Can't wait to go brmm brmm again, it's been off the road for 2 nearly weeks now :(
Edited by Nev, 13 July 2016 - 08:45 PM.
#3169 hairy
hairy
    Moonlander
  • 6,063 posts
Posted 13 July 2016 - 09:04 PM
Glad you got that out Nev - still working on my lambda sensor! How long did you apply your blowtorch?
#3170 Nev
Posted 13 July 2016 - 09:11 PM
Didn't use heat on the stuck bolt if that's what you mean, it was drilled out in the end as the bolt extractors would not budge it due to heat/corrosion probably.
If you can't get any purchase on the lambda, it sounds like you might need to weld some "handles" onto it and then twist it off, or some other sneaky approach. Which lamda is it, front or back? If you can get the exhaust off the car I could try welding some bar on to it for you.
Edited by Nev, 13 July 2016 - 09:34 PM.
#3171 Nev
Posted 16 July 2016 - 04:01 PM
Bolted the car back together and gave it a standing heat cycle up to operating temp in the garage, just to let the gaskets and clamps settle and cool into position and let the oil/grease burn off. Will take it out for a test this evening.
Happened to come across 2 slightly leaking water pipes (to and from the waste-gate), so have replaced these as well.
Edited by Nev, 16 July 2016 - 04:21 PM.
#3172 Nev
Posted 17 July 2016 - 03:44 PM
Took it for a test drive this morning, all seems good, although it unexpectedly sounds a bit different. In fact it seemed really slow but I think it was just an illusion caused by having my boost back at lower rpm and the power curve returning to a straight line again.
Only time will tell if the fix is good I suppose, not bad for £30, If I'd taken it to Courtenays or somewhere similar it would most likely have been around £2000 probably.
Edited by Nev, 17 July 2016 - 04:09 PM.
#3173 Nev
Posted 20 July 2016 - 08:21 PM
Took advantage of the weather today and went for a walk/run up Pen-y-Fan. Somehow the tops of the mountain were covered in cloud by the time I got there, though the rest of the countryside was sweltering.
#3174 ayresyy
ayresyy
  • 490 posts
Posted 21 July 2016 - 06:59 AM
 The weather certainly moves in rather fast up there !
   It caught me out last year on what appeared to bright warm day at the bottom, (granted I was walking slowly as apposed to running up), but I was a lot more fortunate than the 2 poor chaps that went up earlier in the year and were hit by lightening at the top.
#3175 hairy
hairy
    Moonlander
  • 6,063 posts
Posted 21 July 2016 - 06:21 PM
Hot day to go up the Fan. That first pic is ace - got to be a contender for the 2017 calendar!
#3176 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 21 July 2016 - 06:26 PM
Looking good Nev and can't wait till I'm at this stage of just cruising around the countryside 😃
#3177 Nev
Posted 21 July 2016 - 07:06 PM
Thanks guys, yes, belting round the country side with the roof off and the open road in front of you (and a nice walk is really lovely).
#3178 Nev
Posted 22 July 2016 - 01:12 PM
£350 lighter this morning, thanks to my noisy car. :mellow:
Edited by Nev, 22 July 2016 - 01:21 PM.
#3179 CocoPops
CocoPops
  • 17,182 posts
Posted 22 July 2016 - 01:30 PM
Insurance?
#3180 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 22 July 2016 - 01:51 PM
New back box?...
    Google (1)
