Big Power Vxt Project
#3241
Posted 11 October 2016 - 11:46 AM
#3242
Posted 11 October 2016 - 11:52 AM
let me know what you did to the bonnet release bracket and the support plinth underneath. I have bent my bracket up so many times now it looks like something yuri geller has been at.
I'll take a look, my old one might still be fitted in the car, but with the cable detached obviously.
Edited by Nev, 11 October 2016 - 11:56 AM.
#3243
Posted 11 October 2016 - 11:55 AM
Try softening the front up a little?
Yeppers, fiddling with front/rear rebound delta is the next easy thing, I have recently been softening it up both front and rear now that Nitron have fixed my bump stop issue. I might stiffen the rear TBH, as it can wallow on certain bumps at the moment, then maybe soften the front.
Josh's car (very unusually) has a rear ARB as well, I still feel/think this is the best solution, though I suppose the cheaper solution is simply stronger springs on the rear (or softer springs on the front). Anyway, his VX is the best handling one I've ever driven, abeit only at slow/mid speeds (not sure how it would be at high speed on the limit).
Edited by Nev, 11 October 2016 - 12:21 PM.
#3244
Posted 11 October 2016 - 02:10 PM
Another hour in the garage achieved:
1. Reduced front dampers by a click.
2. Re-tighten a turbo to manifold bolt that had unwound and was letting gas past.
3. Put a bit of extra exhaust wrap around the wastegate pipe as the radiated heat off it was melting the bulkhead plastic and making a smell/fire risk.
My current front Nitron springs are 350 Lb, if anyone has a pair available (around 300 to 330 Lb) I'd be keen to snap them up.
Edited by Nev, 11 October 2016 - 02:13 PM.
#3245
Posted 11 October 2016 - 03:13 PM
Hmm, just been out for a blat around. It seems a bit more responsive on the front end, but it may be an illusion. Swapping cars with Josh would give a better idea.
#3246
Posted 15 October 2016 - 07:20 AM
Fooking soggy arse wet cold bloody country, messed up another early morning run
#3247
Posted 15 October 2016 - 09:26 AM
#3248
Posted 15 October 2016 - 02:39 PM
Yep summer seems to have moved out for the year 😞 I does make me worry a touch about wet handling in the ikle Renault 5 turbo with this rather large 5 pot tfsi and 7 speed dsg 😐 Confirm tomorrow if I can retain transverse layout, if not will flip round and go manual box DG
Not to mention it's tiny "turn on a sixpence" wheelbase.
In the end I tackled the Saturday shoppers and took the son of a family friend out for a drive into the Cotswolds. He is a project manager for various aerospace companies and had shown an interest in the car over the last few years. He was pretty nervous as I strapped him in, but fizzing with excitement at the end of 40 miles and full of insightful and penetrating questions
Edited by Nev, 15 October 2016 - 02:41 PM.
#3249
Posted 15 October 2016 - 05:10 PM
Don't tell me you went out without your roof again!
#3250
Posted 16 October 2016 - 12:36 PM
Do you rate the DSG box over the manual?Yep summer seems to have moved out for the year 😞 I does make me worry a touch about wet handling in the ikle Renault 5 turbo with this rather large 5 pot tfsi and 7 speed dsg 😐 Confirm tomorrow if I can retain transverse layout, if not will flip round and go manual box DG
#3251
Posted 16 October 2016 - 02:05 PM
#3252
Posted 19 October 2016 - 08:10 AM
Can anyone confirm if the standard OEM front coilover mounting brackets are compatible with Nitron 1-way coilovers please?
I ask as I currently have some lowering brackets that are not allowing the front wheels to droop enough and want to re-install some OEM brackets instead.
Edited by Nev, 19 October 2016 - 08:12 AM.
#3253
Posted 19 October 2016 - 08:43 AM
#3254
Posted 19 October 2016 - 08:52 AM
I have NTR40's with short spacers, that fit straight into the oem bracket.
I also have a set of Nitron supplied brackets, that are to wide for these nitrons. I think they require wider spacers to be used, like below:
(wide ones left, smaller ones on the right)
#3255
Posted 19 October 2016 - 09:10 AM
Thanks guys.
#3257
Posted 24 October 2016 - 09:14 AM
Useful titanium parts for Nipper - sure to add 50 Leptons.
Over £1 million raised to develop a small metal insert + rubber cap ?!
#3258
Posted 24 October 2016 - 10:39 AM
Plus the fact these
http://www.ebay.co.u...IMAAOSwoQ1Tna8x
are -35dbs as opposed to -10dbs of the linked ones at £2.99 for 20 pairs. But hey it's all about looking cool isn't it.
#3260
Posted 04 November 2016 - 10:51 AM
Car seemed rather weedy last night, might need to check the air filters.
https://photos.googl...FJNSjBCWEM5VGlR
God this site is fcuking crap, it shouldn't be so hard to render an embedded video or picture, after all it is meant to be a primary function of any website!!
Edited by Nev, 04 November 2016 - 10:55 AM.
