taking Nipper on track
you will get ribbed over this, even if you did track it.
I get the same abuse, they are all feckers
Posted 20 November 2016 - 09:51 AM
Posted 20 November 2016 - 10:16 AM
looking forward to see the build
Me too the 1mm and 1.2mm welding is going to be blow-through hell (I think I will cheat and use overlapped joints to double the thickness!)
Edited by Nev, 20 November 2016 - 10:21 AM.
Posted 20 November 2016 - 10:19 AM
turn the power down, weld a spot at a time, chamfer the edges to create a bigger weld surface, easy
Posted 20 November 2016 - 10:23 AM
Yea, a 45 degree chamfer deffo helps, my welder can go as low as 10 amps. If I am fooking it up badly, I have a professional welding friend who can come round and do it for me.
Posted 20 November 2016 - 03:25 PM
Posted 20 November 2016 - 04:00 PM
Some years ago I ran a B1 Chrysler at around 1000bhp. Ran 7 sec quarters with 2x3" systems. I wonder what the gas speed in that was?!
Fooking fast gas speeds, but presumably a very straight run.
Posted 20 November 2016 - 08:46 PM
Posted 21 November 2016 - 12:01 PM
Got the sheet bent up nicely this morning, write up is here (scroll down): https://sites.google...gn/05-build-log
Gonna get my ski salopetes on (it's freezing here) and dive into the garage now for some more fiddling.
Edited by Nev, 21 November 2016 - 12:30 PM.
Posted 22 November 2016 - 01:49 PM
Posted 22 November 2016 - 02:25 PM
I have no idea about where to get 5" pipe Duncan as it was never on my horizon, the prices do vary a lot and hunting around payed off for me. I have to say I'm a bit surprised to see you using it after your comment about my choice of 3.5" being excessive, unless your engine is about 1000 HP.
Had a somewhat long session in the garage again yesterday, lots of time and little to show for it, pics and write up at the bottom of here: https://sites.google...gn/05-build-log
Edited by Nev, 22 November 2016 - 02:37 PM.
Posted 22 November 2016 - 02:34 PM
Posted 22 November 2016 - 03:45 PM
I started mine up without the silencer , just the down pipe and system up to the cat, blimey that sounded like starting up a tank
Posted 22 November 2016 - 05:04 PM
Posted 22 November 2016 - 05:13 PM
Truck exhaust suppliers are best for the bigger stuff. Yes seriously..
Yep I think we all know that, however a truck silencer is extremely unlikely to fit into the void of the VX220. Anything pre-bought just won't utilise the space fully, this is why I am making a silencer from scratch that uses every square inch of the void. Also, I am doing my best to keep weight down, which presumably is not an imperative for a truck silencer.
Edited by Nev, 22 November 2016 - 05:27 PM.
Posted 22 November 2016 - 06:24 PM
Posted 23 November 2016 - 07:16 AM
Last one I bought they made to my dimensions in stainless cost about 150 from memory
Wow, that seems cheap, who exactly made it for you please?
Edited by Nev, 23 November 2016 - 07:17 AM.
Posted 23 November 2016 - 07:57 PM
I made the butterfly valve and welded up the silencer today, pics and write up here (scroll down): https://sites.google...gn/05-build-log
The butterfly valve works rather better than I expected. The 6mm spindle has to be straight so it can poke out of a small 7mm hole in the side end cap of the silencer, allowing the end cap to be pulled off, whilst the butterfly assembly and spindle are still in the silencer can. However I will need to invent some way of connecting a 90 degree arm to it, so that the spring can pull on it. Can anyone think of a way to do this such that the arm is solid and strong, yet could be removed if I need to take the silencer end cap off (labelled as "necessary join" in the pic)?
Edited by Nev, 23 November 2016 - 08:09 PM.
Posted 23 November 2016 - 09:10 PM
Think steam ship paddle?
Posted 23 November 2016 - 09:13 PM
