A bar between the block and the turbo underneath would be enough.
Yea, there are several M10 holes in the block to fix a bolt+bar, but finding some way to mount the other end to the turbo is a bit of a head scratcher.
TBH, I think the problem might be due to the leverage of the exhaust pipe when going over bumps and when the engine twists on acceleration, so I might try making a hanger for the middle of the exhaust pipe to the gearbox/sump area. Or maybe it's just that the bolts/studs fatigue with the heat, they must regularily see 900 degrees C and peaks near 1000 to 1050 degrees as the manifold collector goes bright orange after 30 seconds of booting it.
I'll jack it up tomorrow morning and have a looksie.
Also need to put some new air filters in, that should give me 50 HP back as they were pretty blocked when I checked a few days ago. Apart from that It's going like a rocket (a nice and quiet one until about 5000 RPM too).
Edited by Nev, 06 April 2017 - 07:24 PM.
