Big Power Vxt Project
4722 replies to this topic
#3961 Nev
Posted 26 August 2017 - 09:14 AM
Yep, I think MIG would really help due to it's "filling" nature. At the end of the day, I only have rudimentary cutting tools, so making the parts fit well is next to impossible with gaps of 1 to 3 mm a lot of the time.
I've used MIG before, and even though it looks and sounds horrendous with the splattering and noise, the end result is better welds in general (in terms of fill and penetration).
TIG is fine for exposed buttwelds, but getting into narrow concave bends with both the torch and the rod is much harder than MIG.
Edited by Nev, 26 August 2017 - 09:20 AM.
#3962 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 26 August 2017 - 12:48 PM
Yep, I think MIG would really help due to it's "filling" nature. At the end of the day, I only have rudimentary cutting tools, so making the parts fit well is next to impossible with gaps of 1 to 3 mm a lot of the time.   I've used MIG before, and even though it looks and sounds horrendous with the splattering and noise, the end result is better welds in general (in terms of fill and penetration).   TIG is fine for exposed buttwelds, but getting into narrow concave bends with both the torch and the rod is much harder than MIG.
Get a smaller torch you've probably got a WP26 which is the standard size going to a WP19 will make it a lot easier to get into the hard to get areas. Also you could cut the tungsten down and fit the flat end to reduce the size down even more.
#3963 Nev
Posted 09 September 2017 - 06:42 PM
Did a bit of a high speed run today and just went to fill up fuel for tomorrow's run and discovered the front clam has bent inwards at one of the corners again from the air pressure. This in turn has caused a small downward bend in the front floorpan. I think I need to support it with with some sort of metal stay(s) from the crash-box. On the plus side, the rattly baffle in my silencer seems a fair bit quieter now, perhaps it's detached enough to wedge itself into some corner somewhere!
Edited by Nev, 09 September 2017 - 06:48 PM.
#3964 BadCop
BadCop
  • 96 posts
Posted 10 September 2017 - 07:32 PM
What sort of high speed? I often hit rev limiter at 306 km/h (about 190 MPH - GPS measured) on the Autobahn and nothing bent so far. Do you have a picture of the bent Clam/ floorpan?
#3965 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 10 September 2017 - 07:54 PM
That is serious speed..... :o
#3966 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,843 posts
  • Interests:Big baps.
Posted 10 September 2017 - 08:27 PM
As you approach the speed of light you get heavier. Maybe that's the problem?
#3967 Nev
Posted 11 September 2017 - 06:34 AM
I get the problem because I don't have an OEM front clam, instead I have a GMS front clam (which is lighter and less strong) and also the fixing points are different.
There is a pic here, where you can see the bottom floorpan has a few mm gap between itself and the left most bottom side of the clam. Pic was taken about 3 months ago BTW, it's worse than that now.
Test speed was around 70 MPH, I never go faster than this or CocoPops tells me off. :sleep:
Edited by Nev, 11 September 2017 - 06:52 AM.
#3968 BadCop
BadCop
  • 96 posts
Posted 11 September 2017 - 11:45 AM
Ah OK, that's the reason.
Could you stiffen the GMS-Clam by laminating honeycombs to it?
They weigh almost nothing and even thin fibre stuff becomes very rigid and strong.
#3969 Nev
Posted 11 September 2017 - 11:58 AM
That's a good suggestion, I'll take the wheel off sometime and have a head scratch.
#3970 hairy
hairy
    Moonlander
  • 6,030 posts
Posted 11 September 2017 - 12:35 PM
Expanding foam?
#3971 chris_uk
Posted 11 September 2017 - 02:24 PM
Expanding foam?
Awaits the thread.. how to remove expanding foam from hair. https://encrypted-tb...OCnaRDsy9Ith19Q
#3972 Nev
Posted 24 September 2017 - 11:23 AM
Another summer over I think, got up early this morning to go for a drive but it didn't become light until about 6.15, so I went back to bed. :( Off climbing in sunny Spain for a few months now, so shan't be driving him for a bit.
Edited by Nev, 24 September 2017 - 11:41 AM.
#3973 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 25 September 2017 - 05:59 PM
Imnotworthy
:tt:  :tt:  :tt:
This is probably the fastest speedster ever??????
#3974 Nev
Posted 22 November 2017 - 03:17 PM
Is it wrong to get drunk in the early afternoon, instead of looking for a job ?!
#3975 Nev
Posted 22 November 2017 - 03:26 PM
Imnotworthy
:tt:  :tt:  :tt:
Hmmm.... I'm pretty sure I know of two that go faster than that (and thats not including me (before Cocopops tells me off for going over 30!)).
Hopefully, he is a work (earning NI contributions for me) and unable to respond to this !!
Edited by Nev, 22 November 2017 - 03:51 PM.
#3976 Nev
Posted 22 November 2017 - 03:49 PM
. <-- Too drunk, had to delete that one.... or Cocopopos would have blown a fuse...
Edited by Nev, 22 November 2017 - 04:16 PM.
#3977 Nev
Posted 22 November 2017 - 04:01 PM
Edited by Nev, 22 November 2017 - 04:29 PM.
#3978 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 22 November 2017 - 05:59 PM
Drunk nev.. could be the new you ;-)
#3979 PaulCP
PaulCP
  • 6,066 posts
Posted 22 November 2017 - 06:59 PM
Hate to tell you Nev, but mods can read deleted posts 🤓🤓
#3980 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 22 November 2017 - 07:07 PM
Yes, that's wrong!!!!!!
10 o' clock in the morning is much better!!!!!! (it really is!)
