It was warm enough to work in the garage in a T-shirt this afternoon, so no excuses for me!
Took the old cam cover off and cleaned up the head gasket mating line and put the new cover + gasket on (without silicone this time). I had a quick look at the old gasket and it had become hard, so no wonder it was leaking. This is almost certainly due to heat as it's only about 3 years old, so with this in mind I've made a bit more of a heat shield out of old Nimbus I had lying around, though I think I might have to replace the gasket again in a couple of years as the sheer oil + engine heat is also contributing to it's demise.
It was nice to look down at Nipper's sexy bits again, particularly as it's just so easy to do these sorts of jobs now. Check out those monster cam lobes, 11mm of lift on the inlet side and the sharp/sudden profile for the mechanical lifters. I had a quick look for any scoring or wear and the whole thing looked brand new after some 40,000 miles (thank fook!).
The sexy bits:
Old + new comparison:
Installing the new gasket into the new cam cover:
Final Installation:
Edited by Nev, 18 April 2018 - 02:22 PM.
