Big Power Vxt Project
4722 replies to this topic
#4381 The Batman
Posted 23 August 2018 - 07:16 PM
i need a engine first :lol:
#4382 Nev
Posted 23 August 2018 - 07:17 PM
Let me build you a ZLET and then you can put a Harrop on it to be perverse. ;)
Edited by Nev, 23 August 2018 - 07:18 PM.
#4383 The Batman
Posted 23 August 2018 - 07:19 PM
lawnmower power again for me
maybe i should drive it more on the road to give it a rest :unsure:
#4384 Nev
Posted 23 August 2018 - 07:28 PM
How much will a new engine cost for you?
#4385 Nev
Posted 23 August 2018 - 07:41 PM
A few pics from the second half of the summer, probably double posted from Farcebook, but hey ho...
Edited by Nev, 23 August 2018 - 07:45 PM.
#4386 The Batman
Posted 23 August 2018 - 08:07 PM
alot :(
so its on the backburner until winter (after the house move)
#4387 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 24 August 2018 - 08:35 AM
I'm confused.
Why would you buy TC when it's built into your ECU?
#4388 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 24 August 2018 - 07:13 PM
Love the pics Nev, some great shots
Which Adaptronic unit is yours running? Dave has the tc setup in his and after going out with him works very well
#4389 Nev
Posted 24 August 2018 - 08:08 PM
Yepers, my ECU can be programmed to operate TC, but there is an issue with the hubs needing an inline capacitor each. The cost to get it setup would be much the same as getting this Polish stand alone system, and god knows how many hours of my time.
Instead, with the TC group buy, I can just drive in, sit for 2 hours while he fits it and drive away for circa £300, so it's too easy and cheap of an offer to miss really.
Edited by Nev, 24 August 2018 - 08:17 PM.
#4390 NOSBandit
NOSBandit
  • 271 posts
Posted 24 August 2018 - 09:10 PM
I priced up building a filter for the hubs, even buying the most expensive capacitors and necessary parts it was still less than £20 from RS and that included a case.
Sent from my SM-G935F using Tapatalk
#4391 Nev
Posted 25 August 2018 - 05:47 AM
Thanks NOSBandit, yes it's not really the expense that stopped me, it's the hassle/effort/time and risk of problems.
£300 for a drive in service (that is known to work) is good value and if I didn't seize the opportunity now, I'd probably never get TC. As it is, I've been meaning to get it on my car for about 7 years now but still haven't.
IMO having it will considerably improve safety, and transform the car at/close to the limits so I can go faster/safer. Also I'll be able to use the power in the lower gears without the fear of spin outs in winter.
Edited by Nev, 25 August 2018 - 05:53 AM.
#4392 NOSBandit
NOSBandit
  • 271 posts
Posted 25 August 2018 - 08:55 AM
Hi Nev, the only reason I looked into the filter was to make sure I had myself covered when I installed the racetcs to my car.
But I am glad to say it was not required as I got a stable speed input from the abs sensors at a relatively low speed.
#4393 ditonics
ditonics
  • 939 posts
Posted 25 August 2018 - 09:16 AM
I don't know your ECU Nev but I'm assuming it has functions much like the rest.
In which case using the TC function in the ECU will give you much greater control over the car. The power can be back off via fuel, spark, timing or a combination. Not just spark (I'm assuming that's how this one works)
It will also allow flat shift, launch control and "blip" shift if you have the clutch switch plugged into your ECU. I realise you probably have no interest in these
#4394 Nev
Posted 25 August 2018 - 03:38 PM
Hmm, you're probably right, now you've gone and put a nagging doubt in the back of my mind!
#4395 NOSBandit
NOSBandit
  • 271 posts
Posted 25 August 2018 - 04:27 PM
The racetcs cuts individual cylinders, and it works really well. Adaptronic only cuts fuel or spark, not individual cylinders.
#4396 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 25 August 2018 - 06:17 PM
Nev have a chat with Dave, works really well and as you know car is no slouch. Part of the current ecu offering also and has launch along with other toys. Can be tweaked and tweaked for free :)
Not having a dig at the other product but for you all the options are there ;)
#4397 Nev
Posted 26 August 2018 - 05:06 AM
Useful info, thanks, sounds like RaceTCS could work more smoothly.
#4398 Nev
Posted 26 August 2018 - 05:22 AM
Thanks Dunc, I'm pretty sure I could set it up, but it would take me ages to do the research and set it up. Now I'm working it's more cost effective to just get someone else to install it for me and go to work for 4 hours.
#4399 Nev
Posted 02 September 2018 - 01:18 PM
My gearbox is dieing. :(
Anyone know of a Zafira-A  F23 gearbox for sale please? It's sticker code is "DZ", part number is 24467329.
#4400 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 02 September 2018 - 03:08 PM
It's done well lasting this long if it's the first time it's had issues
    Bing (1)
