Big Power Vxt Project
4722 replies to this topic
#4501 Nev
Posted 27 December 2018 - 05:32 PM
I looked at the slate wall/incline you were climbing and thought - hang on a minute - I recognise that, and then the rest of them. :)
Oh, are you a climber? I used to love climbing slate when I was younger - Comes the Dervish etc.
#4502 oblomov
oblomov
    oblomov
  • 3,853 posts
  • Interests:Mumblers
Posted 27 December 2018 - 10:22 PM
No, it's just local to me. Never climbed, but I used to be able do one arm pull ups, can you? The only other people I knew who could do them were climbers. :-)
#4503 Nev
Posted 28 December 2018 - 07:33 AM
I could do only ever do 80% of one, I could never finish the final part of the pull. Now-a-days I don't cross-train or diet for it, but still love outdoor adventures. I seem to do more surfing and hill/mountain walking now, which is quite a lot easier and safer.
Sounds like your power to weight ratio is excellent, maybe you could give climbing a go?
Edited by Nev, 28 December 2018 - 07:37 AM.
#4504 oblomov
oblomov
    oblomov
  • 3,853 posts
Posted 28 December 2018 - 07:10 PM
Nah, unfortunately I'm an old git now. :lol:
#4505 bigoldhillsroundhere
  • 53 posts
Posted 28 December 2018 - 11:30 PM
I remember Comes the Dervish, horrible crux move at the top with those nasty finger jams after the exposed traverse.
Always prefered last tango in Paris to the the left of the Dervish, same height but always felt like less exposure.
Edited by bigoldhillsroundhere, 28 December 2018 - 11:31 PM.
#4506 Nev
Posted 01 January 2019 - 10:14 AM
Went for an New Year drive into the hills this morning and at about 60 miles in I really booted it hard in 4th gear... I now have a grinding noise in 4th gear as well now, so the gearbox has really had it's chips. :(
I really need to swap the gearbox and differential over, I've already bought and picked up the replacement, I just need to get my lazy arse into the garage for a day and do it. :(
I'm even partly tempted to give it to a garage to get it done, but I fear the expense and the chance (likelihood?) they will will cock it up somehow.
Edited by Nev, 01 January 2019 - 10:21 AM.
#4507 smiley
Posted 01 January 2019 - 11:07 AM
There are no reputable gearbox rebuild shops in the UK?
#4508 Nev
Posted 01 January 2019 - 11:28 AM
Yea, I got a few quotes about 5 months ago, but they want circa 8 times the price of a second hand box (the one I bought was £70 off a Zafira GSI). Cheaper to just install a second hand box IMO, hopefully the one I've bought is fit for purpose and also it has 8% lower gear ratios which I would like. Even if it has problems, I'll just buy another second hand one as they are common and cheap as muck.
TBF the F23 is a flipping amazing gearbox, I can hardly complain considering it was designed for 220 ft/lb, it's amazing how well they last on tuned VXes and a credit to German engineering. You just have to consider them as disposable I guess!
Edited by Nev, 01 January 2019 - 11:37 AM.
#4509 siztenboots
  • 26,613 posts
Posted 01 January 2019 - 11:36 AM
at least you will learn something when you have the old box apart
#4510 Rosssco
Rosssco
  • 4,183 posts
Posted 04 January 2019 - 10:31 AM
Did you go for a 3.95FD ratio gearbox Nev? I think the turbo should have came with these as standard..
#4511 siztenboots
  • 26,613 posts
Posted 04 January 2019 - 10:45 AM
3.63 as standard
#4512 Nev
Posted 04 January 2019 - 03:46 PM
Yep, the Zafira boxes are lower ratio (if the internet is to be believed), probably due to heavier vehicle weight and larger frontal area to overcome air resistance.
There isn't a sticker on the box, but it should be the same as a "DZ" I think (ie 3.95 FD)
Edited by Nev, 04 January 2019 - 03:53 PM.
#4513 Nev
Posted 09 January 2019 - 07:38 PM
Crikey, just read that my mapper has squeezed 860 HP out of his 2 Litre engine. :tt:  Runs on methanol (which is 2 times cheaper than petrol) as well !
Edited by Nev, 09 January 2019 - 07:39 PM.
#4514 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 09 January 2019 - 08:03 PM
His Renault 5 drag car Nev?
Not seen his car for a while but last time I saw it was with new cage and parachute fitted
#4515 Nev
Posted 09 January 2019 - 08:06 PM
Yup, apparently he was leaking boost, once he fixes that he's expecting > 900 HP.
Very impressive.
#4516 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 09 January 2019 - 08:12 PM
Damn that's a chunk more and as you say very impressive.....boy knows his stuff!
He will be mapping my rs3 / dsg powered Renault 5 'once I get done' (syvec s6plus ecu)
#4517 NOSBandit
NOSBandit
  • 271 posts
Posted 09 January 2019 - 09:11 PM
Very impressive.
I wonder what boost he is running now, i think he was running about 3 bar over a year ago!!
#4518 Nev
Posted 09 January 2019 - 09:16 PM
44 PSI to make 860 HP, he's expecting 50 PSI (once he's fixed the boost leak).
Nipper only made 550 HP at 30 PSI, so his VE is very impressive, somehow with just 14 PSI more he's making an extra 210 HP.
#4519 siztenboots
  • 26,613 posts
Posted 10 January 2019 - 10:23 AM
boost is a daft way to think about power
#4520 oblomov
oblomov
    oblomov
  • 3,853 posts
Posted 10 January 2019 - 06:54 PM
The effects of temperature and air density are most observable on an ordinary turbo charged car when you take it out out for an early morning run on a cold day.  You can really feel the difference in power.
