Big Power Vxt Project
4728 replies to this topic
#4561 Talk-torque
Talk-torque
  • 150 posts
Posted 03 April 2019 - 03:30 PM
Anyone seen Nev? 😉
#4562 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 05 April 2019 - 09:10 AM
Anyone seen Nev? 😉
Maybe still passed out with info orgasms
#4563 Nev
Posted 05 April 2019 - 07:00 PM
I've been working too hard. :(
But will be "fixing" that problem soon I think. :)
Edited by Nev, 05 April 2019 - 07:10 PM.
#4564 2-20
2-20
  • 1,317 posts
Posted 11 April 2019 - 06:50 PM
Rumors is that front S2 wishbones are 8 mm longer and Exige V6 ones +15 mm ...
But I never made any measurements...
#4565 Nev
Posted 12 April 2019 - 10:59 AM
I wonder what the nett effect would be if one just plonked a full set of V6 Exige front wishbones on a VX... has anyone tried it, is it even possible without major fitting issues?
#4566 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 12 April 2019 - 05:19 PM
My info is
Lower front VX220 wishbone should be 378
And S2 front lower wishbone is 386mm.
Have someone in here mesured the front V6?
#4567 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 13 April 2019 - 07:34 PM
I could measure my V6 lowers if it’ll help?
#4568 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 13 April 2019 - 08:07 PM
Yes please. And the uppers to would be nice.
Br, Per
#4569 Mopeytitan
Mopeytitan
  • 1,908 posts
    F1.
From centre of bush to ball joint? Or overall length?
#4570 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 14 April 2019 - 08:28 AM
Center of bush and then a perpendicular line to to center of ball joint.  :-)
Br, Per
#4571 joshua
joshua
  • 181 posts
Posted 14 April 2019 - 09:50 AM
Br, Per
Yes indeed this would be very useful. 👍
Just checked my notes and I removed 20mm from hub and 5mm from steering arm to get to 5° kpi so total 25mm increase in upper wishbone length not 20mm as I stated earlier.
If the V6 upper fr wishbones were 15mm longer this would bring the VX kpi down to around 7.5°. I was running at 7° for a while and imo still very worthwhile.
Another variable to check if still using the VX lower wishbone is for and aft position of the V6 upper ball joint in relation to the VX original as a small variation could have a big effect on caster.
#4572 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 15 April 2019 - 03:51 PM
Why do you want lower kpi?
Also do you have any pictures how you elongated the wishbones?
Br, Per
#4573 siztenboots
Posted 16 April 2019 - 08:09 AM
kpi , reduce the lifting effect , balance out the self centering torque. Has caster angle been mentioned as the two are combined.
how many have increased the wheel offset / wider front track?
#4574 joshua
joshua
  • 181 posts
Posted 18 April 2019 - 08:47 AM
Kpi is countered by caster angle on turn in but the both are very much non linear in relation to steering angle. Castor has most influence on camber at small steering angles then kpi takes precedence as steering angle increases hence why VX front camber flops over to positive on tighter turns.
We have been discussing possible effects of increasing scrub radius which can be done with more wheel offset.
The longer wishbones are at the platers atm as soon as they are back I’ll post some pics.
#4575 Exmantaa
Posted 18 April 2019 - 12:43 PM
Next trackday 7/5 at Zandvoort I will experiment with some 5mm spacer plates on my fronts, as calculations show that I now have around +2mm scrub radius with the 205-40-17's om my ET20mm DTC wheels. Curious if I can feel a difference of the +7mm scrub...
#4576 2-20
2-20
  • 1,317 posts
Posted 19 April 2019 - 07:11 PM
You mean a difference of the -3 scrub radius.. ??? Don't you ?
If you are currently at +2, you spacer will add 5 mm of " negativeness ", leading to -3...
Just wondering...
#4577 Exmantaa
Posted 19 April 2019 - 11:48 PM
No, the 5mm spacer adds positive scrub radius, so 2+5... :sleep:
#4578 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 20 April 2019 - 06:07 AM
Do you have stock front uprights and wishbones? How much camber?
Br, Per
#4579 2-20
2-20
  • 1,317 posts
Posted 20 April 2019 - 07:55 PM
Yes...Thank you... I misread another sketch and had it reversed...
#4580 Nev
Posted 08 July 2019 - 05:24 PM
Since jacking my job in 6 weeks ago, I've mostly been away on a 4050 mile (extra slow!) road tour round the Alps + Slovenia + Croatia. I made a point of going up as many passes and tiny roads as I could and rough camped every night in various beautiful spots, often above the snow line.
It was probably the best road trip of my life, contrasting the mountains with the sea and then back to the mountains helped keep the views fresh. Also, going in late May meant the roads had very little traffic. I'd highly recommend it to anyone who likes natural beauty.
Some pics here: https://photos.app.g...dAYtUsTnecKZwv8
Edited by Nev, 08 July 2019 - 05:27 PM.
