Will it not just be a standard 2.2 box with a 3.95 F/D, the standard VXT is a 3.84 F/D, and i cant imagine is a 4.17 F/D or 4.41 F/D
Big Power Vxt Project
#4601
Posted 01 August 2019 - 09:55 PM
#4602
Posted 02 August 2019 - 05:42 AM
Before dis-information from the usual source (chris_uk) leads to a misunderstanding, here is the info I gleaned from a German Opel source.
I have added some cells that compare gear ratios and the Vmax between my old 3.632 FD box and my new 3.947 FD box. Bear in mind the Vmax figures are for my specific car, where my rear wheels rolling circumference are slightly larger than OEM and my max RPM is 8000. MPH values are GPS measured (as opposed to speedo figures).
Hopefully this will eliminate incorrect info from circulating. All in all I have found it suits my car really well indeed, better than anticipated, but I expect that is mainly due to my extended rev range. I'm not sure how it would feel on an OEM VX220 turbo that runs out of puff by 5500 RPM; you might find yourself constantly having to change gear.
Edited by Nev, 02 August 2019 - 05:50 AM.
#4603
Posted 02 August 2019 - 07:17 AM
Nev, presume you used your existing SRT gearing and swapped in a 3.95 final drive?
Do you know where the 5th gear set on the F23 is? On many transverse gearboxes / transmissions, its the last gear set at the opposite of the side of the bell-housing (accessible from the end plate).
Wondering how feasible to add a longer 5th gear (from a WR ratio box - 0.686) to an existing SR or SRT arrangement..
Edited by Rosssco, 02 August 2019 - 07:18 AM.
#4604
Posted 02 August 2019 - 07:38 AM
details here
http://www.vx220.org...ions/?p=1067697
#4605
Posted 02 August 2019 - 07:48 AM
I didn't do anything fancy, just plonked the donor Zafira gearbox straight on to my engine (i.e. I didn't open it up).
When I was looking around on the internet, there was some conflicting info on the 5th gear ratios (SRT vs others). In the end, I am not entirely sure which one I got. Based on the 150 miles I did yesterday with the new box, I need approx 2950 RPM for 5th gear @ 70 MPH (speedo indicated) using a 285mm x 30% profile rear tyre (down to 2mm of tread) - you could use that to extrapolate the 5th gear ratio from that if you want.
Sizten's link looks useful for you. Also, Vocky knows a lot if I remember.
Edited by Nev, 02 August 2019 - 07:53 AM.
#4606
Posted 02 August 2019 - 08:48 AM
I got my information from here https://en.m.wikiped...23_transmission
#4607
Posted 02 August 2019 - 08:57 AM
VECTRA GEARBOXES
4.17 RATIO 16LZ2,20NEJ,C20SEL,X20XVE 90578385 7 00 032 (IDENT SQ)
3.74 RATIO C20SEL,X20XEV,C22SEL 90578390 7 00 037 (IDENT SR)
3.95 RATIO C20SEL,X20XEV 90578386 7 00 033 (IDENT SS)
3.74 RATIO C20SEL,X20XEV, YL000001 - 90578390 7 00 037 (IDENT SR)
(FOR VEHICLES WITH C22SEL PLANT CODE L)
3.95 RATIO Z22SE 90578392 7 00 092 (IDENT ST)
3.84 RATIO X25XE,Y26SE 90578391 7 00 038 (IDENT SK)
3.84 RATIO X20DTL,X20DTH,Y20DTH 90578387 7 00 034 (IDENT SL)
3.95 RATIO X20DTL 90578388 7 00 035 (IDENT SM)
3.74 RATIO X20DTH,Y20DTH 90578389 7 00 036 (IDENT SP)
ASTRA G GEARBOXES
TRANSMISSION,ASSY.,3.95 RATIO X20XEV 90578397 7 00 051 (IDENT SC)
(EXCEPT OPC) (ALSO USE 90470781 7 24 632)
TRANSMISSION,ASSY.,3.95 RATIO X20XER 24426557 7 00 090 (IDENT TS)
(FOR OPC) (ALSO USE 90470781 7 24 632)
TRANSMISSION,ASSY.,3.74 RATIO X20XEV 90578400 7 00 052 (IDENT SH)
TRANSMISSION,ASSY., 4.17 RATIO X20XEV 5 DOOR HATCH 9126007 7 00 088 (IDENT SD)
(FOR SOUTH AFRICA) F48
TRANSMISSION,ASSY., 3.63 RATIO Z20LET COUPE F07 90424091 7 00 091 (IDENT TR)
(NLS.- USE 24451449 7 00 220 AND SUPPLY 90470781 7 24 632)
TRANSMISSION,ASSY., 3.63 RATIO Z20LET 24451449 7 00 220 (IDENT AF)
TRANSMISSION,ASSY., 3.95 RATIO Z20LET MONOCAB F75 24461371 7 00 175 (IDENT DZ)
TRANSMISSION,ASSY., 3.95 RATIO Z22SE HATCH,SALOON, 90578402 7 00 053 (IDENT SF)
(ALSO USE COUPE,ESTATE,VAN 90470781 7 24 632) F07,F08,F35,F48,F69,F70
TRANSMISSION,ASSY., 4.17 RATIO Z22SE MONOCAB F75 9126008 7 00 089 (IDENT SG)
TRANSMISSION,ASSY., 3.63 RATIO Y20DTH HATCH,SALOON, 9126006 7 00 050 (IDENT SB)
(ALSO USE 90470781 7 24 632) ESTATE,VAN F08,F35, F48,F69,F70
TRANSMISSION,ASSY., 3.84 RATIO X20DTL HATCH,SALOON, 90578398 7 00 029 (IDENT SA)
TRANSMISSION,ASSY., 4.17 RATIO X20DTL MONOCAB F75 90578403 7 00 030 (IDENT SJ)
TRANSMISSION,ASSY., 4.17 RATIO Y20DTH MONOCAB F75 90578403 7 00 030 (IDENT SJ)
TRANSMISSION,ASSY., 4.17 RATIO MONOCAB F75 24451455 7 00 844 (IDENT AR)
#4608
Posted 02 August 2019 - 09:00 AM
AF is the identity on a stock VXT gearbox.
Its the close ratio version.
The F23 comes in close and wide ratio with differing F/D and bell housings.
Hope some of the info helps
Edited by ditonics, 02 August 2019 - 09:03 AM.
#4609
Posted 02 August 2019 - 09:15 AM
I always use this website for gear ratios - https://www.opel-inf...triebe/f23.html
As I've always said, if I could only do one mod to a vx220 it would be to change the gearbox
My own NA, which has a close ratio M32 box, accelerates as quick as a 300bhp SC with a 4.17 box
#4610
Posted 02 August 2019 - 09:47 AM
details here
Cheers - looks like changing the 5th ratio along is not possible unless you strip and rebuild..
#4611
Posted 02 August 2019 - 09:48 AM
Vocky do you find 1st of any use with a 4.17? The f23 is kind of limited unfortunately. If you go for a lower fd 1st becomes a waste of space and a higher fd makes 5th a waste even with the so called closer ratio box. I'd love a longer first and then closer ratios.... Keep thinking M23 with big bearings and cooler is the only way.
I've been toying with swapping my gearbox for similar reasons to Nev. I have never needed 5th on track, the shift point is about 155 which is bonkers.
#4612
Posted 02 August 2019 - 09:59 AM
Sounds like the 3.74 or 3.95 ratios are a cheap worth while upgrade (if you can DIY it) for turbo owners, just like the 4.17 is for NA / SC peeps..
#4613
Posted 02 August 2019 - 10:07 AM
I couldn't find the link to the German site. That's the best one by far for gearbox info.
I was actually surprised how useful first still was with the 4.17, still use it just like i normally did with the 3.95.
#4614
Posted 02 August 2019 - 10:46 AM
don't forget to include the costs for workshop to swap the gearbox , which for many will mean rear clam off . Plus you would be probably thinking about changing slave cylinder , inspect friction material at the same time.
#4615
Posted 02 August 2019 - 01:55 PM
#4616
Posted 04 August 2019 - 11:52 AM
Early morning shot from my drive out to the Irish Sea (Aberystwyth).
275 miles of pure fun getting there with no traffic, not so much fun coming back later with tons of traffic.
#4617
Posted 04 August 2019 - 12:10 PM
I'm starting to quite like the washed look, might even get round to washing him a bit more often. Must be a middle aged thing.
#4618
Posted 04 August 2019 - 03:59 PM
#4619
Posted 04 August 2019 - 04:47 PM
Hope the hand brake was securely on 😆
#4620
Posted 04 August 2019 - 06:00 PM
Great pic
Thanks, it was in gear as well. A couple more pics:
Edited by Nev, 04 August 2019 - 06:04 PM.
