Big Power Vxt Project
#561
Posted 19 June 2011 - 02:08 PM
#562
Posted 19 June 2011 - 02:39 PM
#563
Posted 19 June 2011 - 04:07 PM
#564
Posted 21 June 2011 - 12:01 PM
Edited by Nev, 21 June 2011 - 12:02 PM.
#565
Posted 21 June 2011 - 12:05 PM
#566
Posted 21 June 2011 - 12:08 PM
#567
Posted 21 June 2011 - 12:18 PM
#568
Posted 21 June 2011 - 12:41 PM
#569
29 pages on this post.... ive read most, but might of missed it, but what brakes are you running Nev?
parachute plus ejector seat
#570
Posted 21 June 2011 - 01:19 PM
Very good.
#571
Posted 21 June 2011 - 01:28 PM
that would have been on the list of new parts if it was me nev
Why Joe? The clutch cover should be fine, after all its just pressed metal that never gets worn and wasn't blued at all from heating. The friction material on the plate was plenty thick enough too, in fact I could hardly tell it wasn't new apart from all the dust.
I think Stephan had a clutch made specially by Sachs and rated to 720 NM (ie 530 ft/lb). I fear I may need one of these, I dread to think of the cost
Techie: I think the gearbox can take it for a bit, so long as I drive sympathetically, ie only use WOT in 4th and 5th gear.
MBES2: My brakes are just groved discs and Mintex 1144s.
#572
Posted 21 June 2011 - 01:32 PM
#573
Posted 21 June 2011 - 01:59 PM
Sympathetic? After all this work surely unsympathetic on occasion would be good
#574
Posted 21 June 2011 - 02:01 PM
Fingers crossed. They definitely used to build these boxes strong.Techie: I think the gearbox can take it for a bit, so long as I drive sympathetically, ie only use WOT in 4th and 5th gear.
Guess the next option after that is a six speed M32 conversion but, even that would be way out of spec given some of your projected numbers.
#575
Posted 21 June 2011 - 02:18 PM
#576
Posted 21 June 2011 - 02:39 PM
Edited by Nev, 21 June 2011 - 02:43 PM.
#577
Posted 21 June 2011 - 02:43 PM
I would imagine it will be like driving the Pikes Peak Suzuki on Gran Tourismo.
Shudders
Here's to a speedy sort out Nev! This project deserves it, fantastic.
#578
Posted 21 June 2011 - 03:01 PM
Yea, its bloody frustrating to get held back by so called 'uprated' parts limitations. Why Helix can make their clutch cover 4 mm thicker and hence twice as stiff I don't know. Whats the point of an 'uprated item' if it gives up the ghost at just 200% over OEM setup? I paid a bloody fortune for it and expect it to work.
On a slightly more positive note, Stephan must have had this problem, I am hoping Jon can talk to him and get an part number on his clutch setup in the 'Yellow Peril'.
Cliffie: The driveshafts are very meaty, though not sure about the CV joints. The weak point may be the final drive spine in the gearbox, tha looked a little thinner than I would have liked.
It's all so frustrating, as the car is so close to working and Im clearly keen to drive it.
200% over stock is a lot to ask, even on uprated items Nev. You are in uncharted waters here and with anything like this, it is development all the way, just ask NickB777.
In my old days with tuning the old style Mini we really pushed the envelope turbo charging and pushing over 200 BHP and 220 LB/FT and we had to fabricate our own drive shafts as we were twisting splines as well as developing a replacement for the in-board CVs as we were shattering them. We also had to change the internals of the gear box to straight cut gearing and diff to cope with the extra power.
Sadly when you go beyond what is available this is where you end up as nobody has had to develop these parts and bring them to market. I do feel your frustrations.
I want this to work as much as you do
#579
Posted 21 June 2011 - 03:22 PM
#580
Posted 21 June 2011 - 03:24 PM
