Big Power Vxt Project
#581
Posted 21 June 2011 - 03:27 PM
#582
Posted 21 June 2011 - 04:10 PM
is it time for 6 speed nev?
p.s. Jon, has a complete 6 speed setup in his loft
no he hasn't it's sold
#583
Posted 21 June 2011 - 04:34 PM
Edited by Nev, 21 June 2011 - 04:36 PM.
#584
Posted 21 June 2011 - 04:37 PM
#585
Posted 21 June 2011 - 04:39 PM
#586
Posted 21 June 2011 - 05:14 PM
Edited by Nev, 21 June 2011 - 05:25 PM.
#587
Posted 21 June 2011 - 05:53 PM
#588
Posted 21 June 2011 - 06:13 PM
Is the gearbox itself going to be able to cope with that kind of torque? Thought the F23 was only "officially" rated to 230ft/lb. Clearly we've been pushing past that for some time but this is a huge leap into the unknown.
And there has been quite a lot of mentions of geaarbox issues in modified cars on here - mine included.
#589
Posted 21 June 2011 - 06:25 PM
Indeed. I half had you and Zebwatch in mind when I posted that. I still don't understand how a slippy diff works so not sure whether that will have any positive or negative effect on how Nev's gearbox will mechanically cope with that level power.And there has been quite a lot of mentions of geaarbox issues in modified cars on here - mine included.
#590
Posted 21 June 2011 - 06:28 PM
Edited by Nev, 21 June 2011 - 06:30 PM.
#591
However, I will still have to pay Courtenays for taking my gearbox off and fitting it as the car is in Norfolk rather than in my garage where I can work on it
Would it be worth retrieving the car from Norfolk to fit the clutch? Courtenays will charge £500+
#592
Posted 21 June 2011 - 06:29 PM
#593
Posted 21 June 2011 - 06:30 PM
Plus Minno is currently in the middle of a gearbox rebuild. I am sure there are others.
#594
Posted 21 June 2011 - 06:31 PM
Edited by Nev, 21 June 2011 - 06:33 PM.
#595
Posted 21 June 2011 - 06:32 PM
#596
Posted 21 June 2011 - 06:34 PM
Edited by Nev, 21 June 2011 - 06:35 PM.
#597
Posted 21 June 2011 - 06:37 PM
#598
Posted 21 June 2011 - 06:39 PM
Sweet Jesus, please cast a spell to make my gearbox and clutch work !
P11COv, pls can u let me know what happend to yours, and under what torque.
Mine is running 305 Ibft. The sachs paddle clutch fitted by Thorney a few years ago had wear, as did the flywheel. The slave cylinder went which is what put it into courtenays in the begining. I had been experiencing gearbox issues for 6 months before that however. 1st syncro had gone. It was jumping out of third and also stuggling to do into 2nd.
I an not very knowledgable on gearboxes and have mislaid the paperwork. When courtenays gearbox guys took it apart they said the 1st and 2nd gear shaft was buggered. Cant remeber anything more technical than that! It had a full recon for £500. any parts that looked suspect were replaced.
BTW I have done a lot of track work with it on sticky tyres and drive it 'enthusiastically' on the road trying to make the most of its 290 horses.
Edited by P11 COV, 21 June 2011 - 06:41 PM.
#599
Posted 21 June 2011 - 06:40 PM
Day off work and trip to Courtenay's to DIY it?
Yep, I might have to. Catch a fcking train up there for 6 hours, drive it back (partially mapped at least!) (5 hours) and swap the clutch cover at my place. Its my most dreaded task as I've done it 3 times now, but can do it in 8 hours now I roeckon. Then drive it back up (5 hours) for the second half of the remap !!
#600
Posted 21 June 2011 - 06:48 PM
I would be concerned about the internals coping with the (awesome) power and torque The ATB is the least of the long term problems
