Big Power Vxt Project
#621
Posted 23 June 2011 - 04:38 PM
#622
Posted 23 June 2011 - 04:43 PM
#623
Posted 23 June 2011 - 05:45 PM
#624
Posted 23 June 2011 - 07:15 PM
Edited by Nev, 23 June 2011 - 07:22 PM.
#625
Posted 24 June 2011 - 07:34 AM
There are plenty of manufacturers who can supply a clutch which is able to take the torque from yhis engine and alot more, apart from the purchase cost which would need a new flywheel, one of their biggest problems is the are not nice to use in a road car.
I am talking about a 7 1/4 (184mm) twin plate clutch.
You would probably need to get one made to suit the crank bolt pattern, which would not be difficult and made correctly from the right material will not give any trouble (If the Germans have had trouble with their steel flywheels then they have been made wrong)
Steve
this is a supalite 7 1/4 flywheel I had made for me by TTV . Getting a decent streetable clutch was much harder and in the end I changed my mind and went back to a group N spec.
#626
Posted 24 June 2011 - 09:45 AM
Steve
I agree, I suggested to Nev that if he went with a twin plate clutch to go for the heavier flywheel from TTV and possibly down a size in clutch master cylinder.
steve
Edited by steveboyslim, 24 June 2011 - 09:47 AM.
#627
Posted 12 July 2011 - 05:43 PM
#628
Posted 22 July 2011 - 09:39 PM
#629
Posted 23 July 2011 - 05:22 AM
Edited by Nev, 23 July 2011 - 05:30 AM.
#630
Posted 23 July 2011 - 09:34 AM
I rang up Klassen a couple of days ago. Apparently the part may be in the UK by the end of next week (ie. 30/07/2011). He sounded very wooly about it, so I have little faith in it arriving to be honest.
It's been a bloody irritating and shameful experience, for which I have to pay a lot of money. If I had known it would take this long I would have bought my own twin plate clutch system + flywheel and installed it myself and re-delivered the car to CS in far less time.
In my work/industry, if you say something will take 2 weeks and it then take 6 weeks you get a huge bollocking and maybe put your job on the line if you keep doing it. In the motor industry if's just considered normal prcatice and nobody even appologises or give you a courtesy call to tell you whats happening.
Grrr.
This really sucks mate
Hope the wait with be worth it old pal!
#631
Posted 23 July 2011 - 11:47 AM
Keep calling/bugging 'em..
It's very 'un-german', but Klassen and some of the other german Speedster tuners seem to do a lot of technically great work, but are terrible when it comes to keeping schedules and appointments.
Unless you keep on their tail it would not surprise me if it would take months for the part to arrive, if ever...
Like I said.. It's very 'un-german' as I've had dealings with several german firms and also in the car industry and they usually tend to be extremely punctual and concise (OK.. the swiss take that to the extreme, but still..
#632
Posted 01 August 2011 - 09:46 AM
#633
Posted 01 August 2011 - 09:57 AM
Like I said.. It's very 'un-german' as I've had dealings with several german firms and also in the car industry and they usually tend to be extremely punctual and concise (OK.. the swiss take that to the extreme, but still..), but not these
The automotive industry is usually good, the aftermarket tuning industry are frankly terrible and I'm not surprised in the slightest about the delays regardless of the country the tuner resides in.
#634
Posted 01 August 2011 - 01:53 PM
Edited by Nev, 01 August 2011 - 02:04 PM.
#635
Posted 01 August 2011 - 01:58 PM
#636
Posted 01 August 2011 - 06:52 PM
#637
Posted 01 August 2011 - 07:03 PM
Well, I've just rung Courtenay's up and the clutch cover has arrived and been fitted at long last
Now I have to wait anything between 1 and 3 weeks for a spare slot on their dyno for it to have it's map finished![]()
I asked Mark Watts some specific questions about the new map's safety features. Some of you may be interested to hear that OEM and Klassen/Courtenay remaps have the following software features:
1: Detection of unexpectedly high MAP (manifold absolute pressure). If this occurs due to a 'run away' turbo spool, stuck closed wastegate or a vaccuum pipe disconection, the ECU will retard the ignition and/or open the wastegate.
2: Detection of unexpectedly high ACTs (Air Charge Temps). Apparently my map (and probably yours too) start to throw extra fuel in for cooling from 50 degrees C.
3: Knock sensor will obviously work as normal and retard the ignition when pre-ignition is detected.
I have also asked them to give me a print out of duty cycle of the injectors of max RPM as it seems incredible to me that 630cc injectors can squirt for circa 500 BHP at under 80% duty cycle.
Golly, I am getting exceited again. Nipper might be back in my hands soon and more or less fully working!
If you can get the wastegate open when the MAP sensor reads high it would be best... Retarding ignition will increase EGT's, although its better than nothing. Correction against air charge temp is massively necessary on a FI engine. I LOVE knock control, its awesome, we log my engine and you can see the ECU pulling/adding small amounts of ignition on single cylinders in response to knock events :-)
I'm running 630's @ 3 BAR and have very little head room left. I remember you saying you are at 4 BAR so you should be OK.
Looking forward to seeing the results :-)
#638
Posted 02 August 2011 - 01:21 PM
Edited by Nev, 02 August 2011 - 01:25 PM.
#639
Posted 03 August 2011 - 07:23 AM
#640
Posted 03 August 2011 - 11:21 AM
Edited by Nev, 03 August 2011 - 11:23 AM.
