Big Power Vxt Project
#661
Posted 06 August 2011 - 09:17 AM
#662
Posted 06 August 2011 - 09:56 AM
#663
Posted 06 August 2011 - 10:05 AM
Edited by Nev, 06 August 2011 - 10:10 AM.
#664
Posted 10 August 2011 - 07:59 AM
Mark has kindly emailed me the dyno plot which I have attempted to paste below. It looks good to me, fairly flat torque line, though it does drop off a bit more than I was hoping in the higher revs. I suspect this is due to the restriction of the exhaust manifold and perhaps the inlet manifold. There is also a noticable blip at 7300 revs, probably some sort of resonance issue in the breathing, once again possibly exhaust manifold related.
[mod edit to rehost image]
#665
Posted 10 August 2011 - 08:02 AM
#666
Posted 10 August 2011 - 08:16 AM
#667
Posted 10 August 2011 - 08:20 AM
#668
Great news, can't see the graph.
Right click on the little icon (where the image should be) and click open in new tab. and bobs your mothers brother
Nev, looks awesome! That is going to be some beast!
Ignore my comments now as the mods have fixed it...
Edited by StealthVXT, 10 August 2011 - 08:21 AM.
#669
Posted 10 August 2011 - 08:33 AM
#670
Posted 10 August 2011 - 08:34 AM
#671
Posted 10 August 2011 - 08:37 AM
Good news
Looks like lag city until 4-4.5k revs though, but with 8k rev limit you should be able to keep out of that area when you are actually going for it.
Look at the graph and even his lag is producing more than a standard VXT on full power! WOW
#672
Posted 10 August 2011 - 08:44 AM
#673
Posted 10 August 2011 - 09:31 AM
#674
Posted 10 August 2011 - 09:35 AM
does this conclude your epic blog or is this just the beginning
#675
Posted 10 August 2011 - 09:45 AM
#676
Posted 10 August 2011 - 09:56 AM
#677
Posted 10 August 2011 - 10:06 AM
Good news
Given that there is not much to compare power curves for this turbo with, it is similar to the graph shown at http://www.vauxhall-...rbo-t16029.html
Steve
#678
Posted 10 August 2011 - 11:59 AM
#679
Posted 10 August 2011 - 01:07 PM
I respect the build a lot, but I must say I do not like this kind of power delivery at all.
Considering the torque is still gigantic at the rev limit, wouldn't playing with the cam timing a bit move the torque curve earlier in the rpm range ?
Ultimately, I wonder how much you could make it better with a GTX or an EFR ...
That engine uses a GTX turbo.
Cam timming may help, but at the time of the build suitable vernier cam pulleys were not available to trigger the cam sensor.
There was also a limit in the mapping cost so no timming adjustments were tried (I am sure Nev would test your theory if you are willing to pay for the mapping time)
The torque and power curves are very similar to the graph shown from a Mitsubishi evo using the same GTX turbo (the vauxsport iink)
Steve
PS there has been rumors of problems with EFR tubos
#680
Posted 10 August 2011 - 01:37 PM
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
