traction contrl just over rides the driver and reduces engine power
correct, but only for moments that more grip is lost than the driver wants to let go
which is something that can be done via your right foot
wrong for any car, very badly wrong for heavy turbo charged engines
infact it has been found that a certian amount of wheelspin helps with the stability of a car
you know kamm's circle? the more longitudinal acceleration, the less you have left on lateral. TC helps to not letting the longitudinal part getting so high the lateral part gets too small. and physical law is that the moment you just start to lose grip longitudinal you still have plenty of grip lateral. but if you spin the wheels even more, the lateral part gets lost too very fast. THAT means losing stability. TC prevents the wheels to spin too much. the driver sets the limit with the adjuster.
All the traction control will do is automatically reduce the engine power and in some cases such as cornering increase the risk of crashing.
and this is so wrong, my jaw has dropped reading this! the TC reduces power ONLY if one or both of the two driven wheels have a slip ratio larger than what the driver has chosen as a limit with the adjuster on the dash. it does this VERY FAST down to every engine ignition and the moment the slip drops below the chosen limit it stops cutting the ignition at all. so if you chose to operate your car i.e. up to 15% slip ratio which gives some very optimal grip on dry asphalt the TC ONLY cuts ignitions for the time the driven wheels lose grip giving a slip significantly larger than 15%. this keeps the lateral grip preventing(!) the risk of loosing the rear end. and is totally different from anything you could do with the throttle and different from any OEM traction control you find in normal street cars. they have banned TCs from formula 1 some years ago because driving has become too easy making races boring for the audience. the Racelogic TC is purely motorsport breed and you feel that any time it starts to operate.
please don't talk down things you do not know
I am getting myself out of this now because my limited control of the finesses of the english language gives me disadvantage in any hard discussion and offtopic we might get into. I know what I am talking about. and can live very comfrotably with others believing different things.
in my native language this discussion would be much easier to do. sorry.
Edited by cs_, 19 August 2011 - 05:16 PM.
