Job #1 was to investigate the last remaining slight oil leak that I have. Worryingly it seems to be dribbling out of the gap between the gearbox housing and engine block. It is definitely oil rather than brake fluid, so the likely cuplrit is going to be the crankshaft end seal.
At the moment it is hard to see how much I am losing, though it clearly isn't a huge amount as the oil level on the dipstick hasn't moved in 500 miles. To monitor this more carefully I have fabricated a small catch tank out of aluminium sheet that sits diretly under the leak. This will capture all the oil and allow me to inspect it at regular intevals to see if it is getting worse. Additionally, this mini-tank will stop the oil from spraying on the road and allow me to put my floorpan back on.
Job #2 was to investigate the servo vacuum pipe at the manifold end. This looked slightly cracked, so I have put a jubilee clip over the end of it to squish it and improve the pressure over the join. I am hoping this will improve vacuum to the servo, but to be honest as the car idles at 1100 revs my vacuum is never going to be good. Thus I am currently bidding on an electrical vacuum pump on eBay to make my own kit with an adjustable vacuum sensor and relay. This can all be mounted in the front of the car and will allow me to adjust my braking force to suit conditions.
Edited by Nev, 28 August 2011 - 03:01 PM.
