Edited by VXT Tim, 08 October 2011 - 10:30 AM.
Posted 08 October 2011 - 10:30 AM
Posted 08 October 2011 - 12:21 PM
Posted 08 October 2011 - 04:18 PM
Damn it, everything has come to a halt because I have foolishly snapped a bolt by over tightening it.
Posted 08 October 2011 - 05:01 PM
Bolts that snap when tightening up are waaaaay easier to undo than when they snap undoing. Drill and some easy outs or tap it round with a chisel or put a slot in it and screwdriver it.
The machine shop wont have any probs though. Worth getting 6 new bolts if your going to have to get 1 anyway?
Edited by Nev, 08 October 2011 - 05:02 PM.
Posted 08 October 2011 - 05:08 PM
That pressure plate must be mighty as there doesn't look anywhere near enough material to stick 500 odd lbft (or whatever it was)
Posted 08 October 2011 - 05:15 PM
Posted 08 October 2011 - 06:29 PM
Nev, just had a quick read of your last post on the blog. If you suspect that oil is passing up the bolt threads using 243 probably won't fix the problem. As i'm sure you know it's only a threadlock, at work we use a Loctite 577 on threads that are going into oilways etc as it's a sealant.
I'm guessing the flywheel bolts don't already come with threadlock/patchlock on them? Obviously they'd need some applied, might be an idea to put some on them and let it dry overnight. Then add some 577 when you fit the bolts to try and hold back the oil?
The only other one you could look at is Loctite 572 this is a liquid ptfe, but i think the 577 might be a better choice.
Posted 08 October 2011 - 06:55 PM
Loctite data sheet lists 243 as thread lock and thread sealer.
243 works fine if used in the correct quantity and eveything is cleaned and de-greased(oil removed) with a brake cleaner type product.
Steve
Loctite 243
Loctite 243 medium strength threadlocker, suitable for all metal threaded assemblies, Breakaway torque 26Nm
Posted 08 October 2011 - 07:00 PM
Can anyone confirm if they are 6mm or 7mm - every time I measure them they seem different
Posted 08 October 2011 - 07:04 PM
Posted 08 October 2011 - 07:06 PM
Posted 09 October 2011 - 07:44 AM
Steve
Not sure what data sheet you're reading from fella but 243 is only a threadlock AFAIK
Loctite 243
http://www.loctite.c...D=1000000I81L#a
Not a sealant unlike 577
http://www.loctite.c...UID=1000000IY7U
Posted 09 October 2011 - 09:19 AM
Loctite 243
Technical Information
Applications Thread Sealing and Threadlocking > Threadlocking
Loctite 577
Applications Thread Sealing and Threadlocking > Thread Sealing
Posted 09 October 2011 - 02:00 PM
If it was a sealant i'd think they'd put it in the Thread Sealing section rather than the Threadlocking.
Yes 243 is a threadlocker with improved oil tolerance but for Nevs particular application it's obviously not up to the job in hand. By only using threadlock the bolt thread still has a (albeit microscopic) air gap. This is why i'd think a propper sealant is what's needed also, an anaerobic thread sealant which "fills" the gap if you like and cures in the absence of air. Apologies if i sound like i'm trying to make you suck eggs so to speak.
Difference of opinions/understanding maybe mate but if you look:
Loctite 243
Loctite 577
Posted 09 October 2011 - 04:10 PM
Posted 09 October 2011 - 08:32 PM
Posted 11 October 2011 - 02:29 PM
Posted 11 October 2011 - 04:35 PM
Posted 12 October 2011 - 08:05 PM
Posted 12 October 2011 - 08:12 PM
