Big Power Vxt Project
#861
Posted 12 October 2011 - 08:14 PM
#862
Posted 16 October 2011 - 07:10 AM
#863
Posted 16 October 2011 - 07:25 AM
CongratulationsNipper is now up and running
#864
Posted 16 October 2011 - 08:04 AM
#865
Posted 16 October 2011 - 08:38 AM
I need to get a move on! Be popping down hopefully late October/early November to have a look around the area. ...start new job 3rd Jan!...when are you coming down to Bath BTW? We must meet up.
Once I've decided when I'm popping down, I will give you a shout
Edited by Ormes, 16 October 2011 - 08:38 AM.
#866
Posted 16 October 2011 - 09:00 AM
#867
Posted 16 October 2011 - 12:41 PM
I had a drive shaft before that i thought was all the way in but wasnt so leaked a bit. took me pushing and someone pushing on my back to pop it in properly and was fine then. worth a check
I'm fairly sure I have them whacked in the correct distance but will check. I fear I was a bit too casual extracing the driveshafts last time and I think this leaky one was caused by accidentally tearing the seal
In the mean time, I have installed my aux vacuum brake pump and taken Nipper for a test drive. I have written about it here with some pics and results.
#868
Posted 27 October 2011 - 05:12 PM
#869
Posted 27 October 2011 - 07:10 PM
#870
Posted 27 October 2011 - 07:49 PM
Blimey, I just counted 5 adaptors on your turbo oil feed pipe! If you want to pop the pipe into us we will happily braze a new end on it to reduce that to one!
LOL, yes, it is a hell of a string of adapters from the male BSP OEM hard pipe. In the middle of that lot is a male AN6 teminated 30 micron gauze filter to protect the turbo, so the stack of converters was rather shocking. Amazingly however, it doesnt leak what so ever ! Also, I dont think my turbo weaps any oil, so the pressure that arrives to it seems to be right - surprising really, as I thought the pressure the pump would deliver would leak past the seals which are meant to cope with arround 80 PSI. I think the final AN4 flexi pipe which is quite narrow helps restrict the flow.
Thanks for the offer of the brazing, though if I thought about it I am sure I could find you a few more important jobs to fix on my car
Edited by Nev, 27 October 2011 - 08:01 PM.
#871
Posted 27 October 2011 - 08:29 PM
#872
Posted 28 October 2011 - 03:17 AM
#873
Posted 28 October 2011 - 10:12 AM
#874
Posted 28 October 2011 - 04:54 PM
#875
Posted 02 November 2011 - 06:08 PM
Write up here.
It's funny that I am now running 3 PSI less boost to make 500 BHP than a stage 4 car does to make 300 BHP. This is all to do with making the engine breath better and increasing the engines dynamic VE (volumetric efficiency), partly by virtue of the turbo and party due to these seemingly minor mods I make.I love all this R&D work, I wish it was my full time job really.
Edited by Nev, 02 November 2011 - 06:15 PM.
#876
Posted 02 November 2011 - 06:18 PM
#877
Posted 02 November 2011 - 06:32 PM
Edited by Nev, 02 November 2011 - 06:35 PM.
#878
Posted 02 November 2011 - 07:16 PM
#879
Posted 03 November 2011 - 12:21 AM
Just out of interest has the increased pressure/braking affected the ABS?
Do you get Ice mode more often braking hard?
#880
Posted 03 November 2011 - 07:31 AM
I imagine like most people he has the ABS switched off
