Big Power Vxt Project
#941
Posted 14 November 2011 - 12:24 PM
#942
Posted 14 November 2011 - 12:58 PM
#943
Posted 14 November 2011 - 05:20 PM
#944
Posted 14 November 2011 - 05:29 PM
Siztenboots.........been away for a few days.
My fault sorry................try this www.driveespana.com
Korkey
if we were to fly out 17th, flights ~£40 each way, and stay at the same place Hotel Abentofail, €71 a room for 2. The Guadix trackday is the 18th April.
#945
Posted 14 November 2011 - 09:18 PM
#946
Posted 15 November 2011 - 07:25 PM
Edited by Nev, 15 November 2011 - 07:26 PM.
#948
Posted 18 November 2011 - 05:33 PM
Nice little write up there Nev. And i know what you mean about the escort cossie. My old boss has one 410bhp and exactly the same off boost seemed tame. But in some way having it like that is better because when on boost it feels even more brutalAfter 3250 miles of driving the car I have written up a 'warts and all' description of the driving experience HERE.
#949
Posted 18 November 2011 - 06:01 PM
Providing you are above 4000 revs, full boost power delivery can be resumed in approx 1/5th of a second by pressing the accelerator.
Edited by spuk87, 18 November 2011 - 06:01 PM.
#950
Posted 19 November 2011 - 09:05 AM
I'd just like to tell you how much I admire your work and your attitude! Yesterday I read your conclusions and I am very impressed. Funny, how my approach to the working process goes conform with yours.
Especially
cannot be emphasized too much. This is the most important part for me. Don't haste, don't hurry, don't get into someone else's garage where you have to get out again few days later. Take your time. And if you do not see the next step, take yourself time to think about it. Do something else. And some days later you get back to work with fresh ideas and less pain in your stomach. The effort will be big this way. With a minimum possibility of doing things wrong.10. Try and do you build somewhere you can just lock up and walk away from when pissed off.
Congratulations! You've done a great job. I really enjoy reading your blog.
#951
Posted 20 November 2011 - 08:05 AM
Nev,
Especially
Thanks for your comments Carsten.
Yes, taking your time and a relaxed approach lets you consider all options and do the right thing. I think it also saves money on wasted/wrong parts.
Let me know if you need any help/advice on anything, am always happy to help a serious 'moder'.
Edited by Nev, 20 November 2011 - 08:06 AM.
#952
Posted 20 November 2011 - 10:00 AM
#953
Posted 20 November 2011 - 10:15 AM
Good write up Nev and some great advice in there. Interesting how you prioritise a cam change. As you know, I'm still on stock cams but half looking to experiment with something different so would be interested to know your thoughts. Trouble is, nobody that I've come across has ever tried a change of cams in isolation, its always don't at the same time as head/valve work which makes it very hard to register what gains you're actually getting. What I would really like to do is spend a day at the dyno and test, say, three different profiles but to do that you need to find a cam company who actually cares about improving their product and not just selling their standard off the shelf stuff!
that'll be CatCams or Newman then.
#954
Posted 20 November 2011 - 10:16 AM
Indeed, cams are nearly always inserted as 1 of a whole batch of mods
I am fairly sure my cam duration has a lot to do with my sinusoidal torque graph, though this is a subjective view, based only on what I've read about moving the peak VE (ie torque) further down the rev range. As I am sure you know (but others might not), this promotes more power when at high RPM at the expense of loss of torque at low RPM. This is certainly a characteristic in Nipper now, hence my guess that the cams have been quite influential on the way that power is delivered. Having said that, Nipper does also have a heavily modified head/inlet including:
1. Solid lifters to give a more precise valve lift, particularily at very high revs. This also provides security from the terrible effects of valve float.
2. Aggresive ramp angles on the cam lobes to take advantage of the solid lifters, thus keeping the valves open for longer.
3. All ports carefully (and expensively!) opened out by an F1/Pro-drive supplying professional with 30+ years experience.
4. Waisted valve stems.
5. Cut down Audi valve guides.
6. Modified inlet plenum.
All these mods will have quite an effect too, so as you correctly point out, it hard to know which ones are affecting what characteristics. However, in conjunction they make a lot of power with just 1.35 Bar of boost. I think if I let CS map it to max boost (2.5 Bar) it would make 580 to 620 BHP, so these mods HAVE to be helping.
I have just replaced my Bailey dump valve with a second hand Forge unit this morning, so I am off for a test drive to see if it makes a difference. Also, Techieboy has kindly posted me his DB meter, so I am sticking that in the cabin so see what the sounds levels are.
I've also installed another mod but can't reveal it
Edited by Nev, 20 November 2011 - 10:25 AM.
#955
Posted 20 November 2011 - 10:46 AM
#956
Posted 20 November 2011 - 11:47 AM
Edited by Nev, 20 November 2011 - 11:52 AM.
#957
Posted 20 November 2011 - 11:50 AM
#958
Posted 20 November 2011 - 03:10 PM
#959
Posted 20 November 2011 - 03:20 PM
Just looking on t'interweb cam options and stumbled across Nippers power graph on dyno-plot. Interesting to compare and contrast with mine http://www.dyno-plot...honda/index.htm
Mine is running more boost and race fuel, Nipper has a turbo that flows more air in theory so that needs taking into consideration. On that run we only went to 7000rpm, but power reduces after then so mine would be loosing out anyway. Interestingly, mine makes a good amount more power low down, like 80bhp @ 4k but then Nipper holds out at the top end better. Peak torque is incredibly similar but obviously we are comparing these two cars on different dynos too.
Bloody hell Chris, your turbo is spooling up 500 RPM earlier than mine - that is a lot. However, as you say I have a lot more boost available, not that my gearbox/clutch could take much more. I just had a look at the Sadev and Quiafe websites, they dont even make a FWD gearbox that can take 350 ft/lb, let alone 450. Pathetic.
I am working on some air-flow mods ATM (airbox, larger pipework, massive TB) - I think these will liberate quite a bit of power at the very top end, maybe 10 to 25 BHP.
Im bored, need another project now. I'd love to learn how to weld and make a single seater from scratch and put one of my engines in it - realistically though, it's not likely to happen as I dont have enough garage space.
Edited by Nev, 20 November 2011 - 03:22 PM.
#960
Posted 20 November 2011 - 03:26 PM
Google (1)
