Almost directly across from Piper!Wish you'd said, they were at Autosport!
never knew or would have spoke to them
Big Power Vxt Project
#81
Posted 18 January 2010 - 07:53 PM
#82
Posted 18 January 2010 - 07:59 PM
Did not want to rub it in that much Theo
#83
Posted 18 January 2010 - 08:05 PM
Oh, I thought you meant that you didn't see Ferrea.Almost directly across from Piper!Wish you'd said, they were at Autosport!
#84
Posted 18 January 2010 - 08:18 PM
#85
Posted 18 January 2010 - 08:35 PM
I know the head work is not all that significant really. Talking to Neil Roper (who will do it), he said his porting will make approx 3% VE gains. Going from 8.5mm OEM lift to 10.5mm and +1mm dia inlet valves and exhaust valves should add approx 5% more power (and better low end torque). Solid lifters will add approx 10 BHP owing to more agressive lift and drop profile. This all adds up to approx +40 bhp ontop of approx 410 BHP (with a GT30R71 setup), or +50 bhp ontop of approx 460 BHP (with a GT30R76 setup).
I am keen to make the effort with the head, as it can be transfered easily to another block in case something drastic happens to the first block! Also, by making sure the head is flowing as well as it can, I can move up to a GT35 or even a GT40 should I chose to in the future, just for the price of a turbo and a remap. Thus, you can see that I am still fairly determined to do this project right, from the outset.
I await feedback from Ferrea (BTW I was aware that they were at the 'fair'), as Steveboyslim was talking to them (and Piper) for me.
It's interesting to hear that CS have bought all those Cosworth pistons...
If I get time I also may fabricate a new airbox with Dave H, as the OEM will be causing quite a bit of P1 losses if asked to flow for 500 BHP.
Went for a nice drive on snow free and semi dry roads today, it reminded me of why I am going to all this bother...!
Thanks for the condondement RedVts, I hope my blog raises a bit of spirit in the site and perhaps someone may follow my footsteps with a VXT one day (assuming mine ever runs well!).
Nev is there really a need to do that much work with the head? Does Stephan do much with his (thinking of the only other person running mega power)?
If you have oe ones can a decent company not copy and spec to the larger size required? Would not think it was that hard tbh
Will give you a shout when the cams are in and let you know what they likebeen speaking with Dave H about inlet manifolds and we have a few options that may help you
also been talking with the companies about your piston options and think the 600bhp rating of the new superspec pistons should be just fine Dave getting more tech detail onit) they are also releasing some H rods in the next few weeks that include under piston oil spray (not as good as LEH setup but a step forward
CS have purchase the complete stock of cosworth pistons at the moment
Also working hard on a new inbox for the crazy ones in the group
DG
Edited by Nev, 18 January 2010 - 08:37 PM.
#86
Posted 18 January 2010 - 09:05 PM
#87
Posted 20 January 2010 - 05:21 PM
Edited by Nev, 20 January 2010 - 05:22 PM.
#88
Posted 22 January 2010 - 08:32 PM
Edited by Nev, 22 January 2010 - 08:36 PM.
#89
Posted 22 January 2010 - 08:38 PM
#90
Posted 22 January 2010 - 09:54 PM
#91
Posted 23 January 2010 - 10:03 AM
Edited by Nev, 23 January 2010 - 10:34 AM.
#92
Posted 24 January 2010 - 05:26 PM
Edited by Nev, 24 January 2010 - 05:28 PM.
#93
Posted 24 January 2010 - 08:04 PM
http://www.astraowne...ad.php?t=231119
built by regal iirc
Edited by cheeky_chops, 24 January 2010 - 08:06 PM.
#94
Posted 25 January 2010 - 08:35 PM
Edited by Nev, 25 January 2010 - 08:35 PM.
#95
Posted 30 January 2010 - 07:09 PM
#96
Posted 30 January 2010 - 09:53 PM
#97
Posted 31 January 2010 - 08:19 AM
#98
Posted 01 February 2010 - 07:38 PM
Edited by VXT Tim, 01 February 2010 - 07:40 PM.
#99
Posted 01 February 2010 - 09:05 PM
#100
Posted 02 February 2010 - 12:13 PM
I agree, my car in the wet can barely plant more than 100 BHP down (particularily becuase of the 888 tyres). However, in the dry with a good surface and in a moderately straight line it could easily plant 400 BHP down (once over say 50 MPH). Anyway, I am not doing this project just to make my car go faster, another goal is to simply see if I can do this and as a result get to understand my engine fully.
As for wider wheels/tyres on the rear, I fear this would affect handling a good deal and would require bodywork changes over the rear arches to accomodate, not something I'd want to do really. I would prefer to simply not press the accelerator so hard!
BTW if you find you are wheel spinning in 2nd gear, try fitting Toyo 888s, I get very little slip with them.
Nevster.
Nev I keep checking in on this thread for updates, every time i log on i hope there are advancements.
I was thinking about a vx with over 400hp today and what it would be like to drive it, i can't help thinking it will be completely uncontrollable.
Unless the road is flat, dry, straight, smooth and nothing else on it it's going to be a right handful. My pitiful 250hp can be an issue in 1st and 2nd.
Can you fit wider tyres on the back although this will surely only make a minor improvement??
Just thinking out loud.
EDIT i'm not questioning the need for more power, that would be ridiculous. You can never have too much power, just not enough grip.
Bing (1)
