Big Power Vxt Project
4722 replies to this topic
#1241 MrSimba
MrSimba
  • 5,197 posts
Posted 08 October 2012 - 09:16 PM
Just checked your update Nev... watch you don't get sucked through the back of the seat into the engine!!! ;)
#1242 TIP
TIP
  • 959 posts
  • Interests:cars. sci-fi, rum, bass, sheds, making stuff, fixing other stuff (mainly plastic vauxhalls) and other geeky bloke stuff
Posted 08 October 2012 - 09:45 PM
surely if you are sucking that much air out of the cabin , unless you have the windows open there will be a horrendous whistling noise through every gap. either that or your ears will pop and you will need to fit drop down oxygen masks
#1243 Darcini
Darcini
  • 2,508 posts
Posted 08 October 2012 - 09:50 PM
:yeahthat: Wouldn't recommend giving pax to any females with implants either
#1244 Nev
Posted 09 October 2012 - 06:00 AM
Hmm, you chaps do have a good point on reflection. I've just done the calcs and at just 500 BHP the air demand from the engine will be around 750 cubic feet per minute. To put that into context that is a room full of air that measures 9 feet * 9 feet * 9 feet. As the cabin is approx 1/6 of that size, that it means the engine will suck the entire air out of the cabin in just 10 seconds !!!! :excl:
I think I will try harder to find another solution, though it is hard as there is almost no room in my engine bay for 4" diameter pipework. :( I might have to stick some sort of air scoop out of the bodywork (which I am not keen on) as my original plan of routing the 4" pipe to the boot to allow fitment of the air box in the there won't fit. Once the 4" bends and alu pipeing arrives in the post I will have a better idea of what I can and can't fit into the engine bay.
Edited by Nev, 09 October 2012 - 06:06 AM.
#1245 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 09 October 2012 - 06:39 AM
What about a coupe back coupled with the exige roof scoop? You could source your cold air from there and it will also give you addition room. Another bonus would surely be the airflow over the rear of the car being greatly improved. With the air staying attached all the way to the rear of the car would this allow for a smaller wing with a shallower angle of attack?
#1246 Nev
Posted 09 October 2012 - 07:36 AM
Hi Tim, yes thats a viable solution, however I would not want to loose my rearward visibility, so I'd have to fit perspex which might look a bit funny. Also I want to stop spending money on the car and the new fast back once its been sprayed and fitted will be over £1000 I reckon.
#1247 MrSimba
MrSimba
  • 5,197 posts
Posted 09 October 2012 - 07:43 AM
A snorkel of some kind Nev? leading into an enclosed box behind your seat with the twin filter set up?
#1248 oakmere
oakmere
  • 2,143 posts
Posted 09 October 2012 - 01:17 PM
Sorry Nev had too laugh at this. I can see the headlines "man suffocated by turbocharger". Can you somehow cut through the rear of the sill ( area where the rear clam bolts are) into the wheel arch area? You could then fit an air feed from each side into an enclosed box behind you.
#1249 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 09 October 2012 - 01:56 PM
I'd drive with the windows down then use a snorkal for yourself. Who cares about practicality
#1250 Cookies220
Cookies220
  • 2,721 posts
Posted 09 October 2012 - 05:58 PM
How about opening up the floorplan just behind the cabin. If you're sucking that much air from under the car it'll be glued to the road!
#1251 Boombang
Boombang
    Saxo boy
  • 3,022 posts
Posted 09 October 2012 - 08:11 PM
Worked for Brabham!
#1252 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 09 October 2012 - 08:23 PM
Finger in air I'd suggest you are going to get many many times more air in through the 'ears' than sucking in from the cabin surely?
#1253 siztenboots
  • 26,613 posts
Posted 10 October 2012 - 07:41 AM
I don't like the thought are getting a free ear syringe everytime I get boost
#1254 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 10 October 2012 - 07:44 AM
Off topic but what is that?
#1255 Wolfstone
Wolfstone
  • 12,986 posts
Posted 10 October 2012 - 07:45 AM
Lotus (obviously) 340R
#1256 Goosenka
Goosenka
  • 12,716 posts
Posted 10 October 2012 - 07:46 AM
Never seen that before. Not very nice is it.
#1257 Nev
Posted 10 October 2012 - 12:52 PM
Thankfully I have been able to just fit the pipework so it pulls air from the boot now (instead of the cabin)... pics + update here.
The 4" pipework is immense, it is almost the same cross sectional area of my plenum. I hope the engine doesnt rock around too much and crush/damage the pipework.
#1258 siztenboots
  • 26,613 posts
Posted 10 October 2012 - 01:01 PM
not a lot of room to pack in 4" cold feed
#1259 MrSimba
MrSimba
  • 5,197 posts
Posted 10 October 2012 - 02:01 PM
Wow! Looks immense! :) Whats the plan Nev? Custom 2 panel airbox in boot and take a hole saw to the rear clam?
#1260 VXT Tim
VXT Tim
  • 11,421 posts
Posted 10 October 2012 - 02:13 PM
Naca ducts on top but to the side of the rear clam? 2 feeds, 1 either side.
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
