Big Power Vxt Project
#1321
Posted 28 October 2012 - 09:06 PM
#1322
Posted 28 October 2012 - 10:03 PM
#1323
Posted 29 October 2012 - 08:14 AM
#1324
Posted 01 November 2012 - 09:26 PM
BTW, Nippers 3" exhaust is up for sale for £900 - advert here.
Edited by Nev, 01 November 2012 - 09:26 PM.
#1325
Posted 03 November 2012 - 12:32 PM
Edited by Nev, 03 November 2012 - 12:34 PM.
#1326
Posted 03 November 2012 - 02:20 PM
Edited by Nev, 03 November 2012 - 02:21 PM.
#1327
Posted 03 November 2012 - 02:44 PM
#1328
Posted 03 November 2012 - 04:48 PM
Edited by Nev, 03 November 2012 - 04:54 PM.
#1329
Posted 03 November 2012 - 04:51 PM
#1330
Posted 03 November 2012 - 04:55 PM
Edited by Nev, 03 November 2012 - 04:59 PM.
#1331
Posted 03 November 2012 - 04:57 PM
#1332
Posted 03 November 2012 - 05:13 PM
It's laughable how home-made some of my contraptions are, but they seem to work fine. I think one of the pragmatic principles of 'DIY tuning' is to fabricate from whatever materials/skill you have to hand, otherwise your project will be limited to 'off the shelf parts' and hence compromised (badly). After all, few of us have metalwork tooling, so in my case I simply use wood and epoxy instead. In the case of this mod, appearances not-withstanding this MAF will flow for around 700 BHP and cost me approx £5. If I were to buy a similar off the shelf part, god knows how much it would be, perhaps £200 or £300.
Edited by Nev, 03 November 2012 - 05:16 PM.
#1333
Posted 03 November 2012 - 05:26 PM
Thus, the decission is whether to risk possibly loosing some fine pedal control < 4000 RPM for the sake of more power at the upper end. Basically this translates into same old ying-yang "equation" you need to consider every time you intend to make a mod. The answer to this question is based on a basic premis that the engine power delivery has always been focused on 4000 to 8000 RPM, below this is less important really as it not within the intended 'powerband'. Thus the answer is to increase TB diameter.
Edited by Nev, 03 November 2012 - 05:36 PM.
#1334
Posted 03 November 2012 - 05:32 PM
#1335
Posted 03 November 2012 - 06:04 PM
You not fancy entering the seloc sprints next year nev? Actually prove the car on track? Time attack? (Might be a bit costly for a OHW though)
Hmmm, hard to answer that question as there are so many variables and factors. I have to say on the one hand I am not keen on paying what amounts to thousands of pounds to be restricted by artifical rules, limited dates/times, fixed venues that are miles from home, and worse noise limits than the road! However, I know what you are angling at, you are keen to see if the car is fast. However, I already know it is quick (on the right sort of tarmac/conditions) and I'm not so young that I feel I have to prove anything. Contrary to all that though, I know deep down that large/fast race tracks is where it would best belong, though I only ever spec'ed it to be a nippy road car.
However, the car isn't what I'd consider ready yet. I am still waiting for some very expensive bespoke parts I had drawn up in CAD and machined up for me. Once these are on the car they should make a radical difference. If they test out well I will be offering them to other VXers. Also I am waiting on another unrelated (so called Motorsport) part under warranttee to be machined up for me which has already failed on the car in just a couple thousand miles.
We shall see what the wind blows
Edited by Nev, 03 November 2012 - 06:11 PM.
#1336
Posted 03 November 2012 - 07:29 PM
Edited by Nev, 03 November 2012 - 07:31 PM.
#1337
Posted 03 November 2012 - 08:01 PM
Maybe not but having sensitivity in the power delivery below 2000rpm is quite useful for stop/start traffic & hill starts!!!
Even more so with paddle clutches!
Edited by MrSimba, 03 November 2012 - 08:02 PM.
#1338
Posted 03 November 2012 - 09:17 PM
Hmm, that didn't go too well.
I installed the new 102mm MAF into the car, started it up and the AFR guage swung around from 16 to 21 (in closed loop) - far far far too lean. It's hardly surprising as the cross sectional area of the new MAF is +33%, so the car will be running 33% lean. I think this is too much for my adjustable FPR to compensate for. This is because the standard fuel rail pressure is 3.3 Bar. If I raise this to it's max of 5.0 Bar, that will increase fueling by 23% (ie still a 10% defecit of fueling). This is all ball park, but clearly I can't run around 10% lean, even if the dynamic fuel tabs compensated for another approx 7%
Looks like I will have to swap back to the old MAF for the moment and consider a dyno run and remap at CS if I want to use it. This is not such a bad things really, if I plonk the larger throttle body on as well it makes sense to get the map adjusted correctly rather than chance it with estimated AFRs.
Running true 80mm i/d over stock 80mm o/d mapped setup runs like a 3 leg donkey let alone bigger. Always going to need mapping to work on oem management sir
DG
Edited by Duncan VXR, 03 November 2012 - 09:20 PM.
#1339
Posted 04 November 2012 - 08:09 AM
#1340
Posted 04 November 2012 - 08:18 AM
Nev I'd be worried that if the epoxy cracked bits of it could get sucked straight into the turbo?
The silicone RTV you recommended for my oil leak may be a better solution? Heat resistant & flexible?
