Big Power Vxt Project
#1421
Posted 20 November 2012 - 07:22 PM
#1422
Posted 20 November 2012 - 07:28 PM
In a word 'no' (hence my caveat above saying this has not yet been substanciated). I've updated things on the blog to make this clearer.
Will your new tuners be able to do a remap with the larger injectors?
Yep, he is a very clever guy and tunes race cars most of us can't even dream of driving.
I'd want to confront them about it. I know it'd get you nowhere but it would make me feel better letting them know you know what they did!!!
I've had enough confrontation on this website to last a lifetime, so I won't be doing that. They are a good company for stage 1,2,3,4 etc, but I think project Nipper was a bit OTT for them. The whole thing was a bit of a suprise for them I think, mistakes happen, I have to move forward and at least the engine is still fine.
First dibs on your injectors!
LOL you vulture! TBH I am finding the car scary fast now, so have decided to keep the current injectors (even though they are maxed out) and just increase the MAF to 4". FPR will be set to 5.0 Bar (if it's not there already) and boost limited to 2 Bar. This will keep the fuel rail at 7.0 Bar dynamic pressure which the 044 pump can just about keep up with.
Edited by Nev, 20 November 2012 - 07:58 PM.
#1423
Posted 20 November 2012 - 10:52 PM
You will need either two 044 pumps or one 413 (£480 + vat) has the same capacity as an 044 upto 8 bar.
The 413 is identical in size and has the same fittings as an 044.
Steve
PS can you tell me where I can buy one of those woolly jumpers ?
#1424
Posted 21 November 2012 - 07:49 AM
#1425
Edited by Nev, 21 November 2012 - 07:51 AM.
#1426
Posted 21 November 2012 - 08:46 AM
#1427
Posted 21 November 2012 - 09:42 AM
I've been looking at the TB and 90' setup and I am surprised you get it all to fit with the original boot lid. The fuel rail is different, I could not see the usual valve for a gauge.
The fuel rail is OEM and deffo has the schraeder valve connection on it - it must be out of sight of whatever pic you saw. The TB and silicon tophat do fit quite reasonably and there is room for the engine to twist/rotate. I am itching for the rain to stop so I can take it for a test drive and see how it feels.
If this mod works well, the old re-bored (larger) 62 mm throttle body and also my super large 76 mm top hat will be up for sale. Both good for around 450 BHP before they cause a bottle neck.
Edited by Nev, 21 November 2012 - 09:44 AM.
#1428
Posted 21 November 2012 - 05:41 PM
Larger throttle body.
Larger top hat.
Larger inlet pipe to turbo.
Bypass valve to stop 'turbo turkey' sound and jolting.
3" exhaust system, with 450 BHP rated race cat.
If you put that lot on your stage 4 car in conjunction with a Klassen inlet manifold you will get 330 BHP (if your rods can cope).
Edited by Nev, 21 November 2012 - 05:41 PM.
#1429
Posted 25 November 2012 - 09:39 AM
#1430
Posted 25 November 2012 - 09:45 AM
#1431
Posted 25 November 2012 - 10:16 AM
#1432
Posted 25 November 2012 - 11:12 AM
Edited by Nev, 25 November 2012 - 11:13 AM.
#1433
Posted 25 November 2012 - 01:16 PM
#1434
Posted 27 November 2012 - 08:31 PM
#1435
Posted 27 November 2012 - 09:31 PM
Edited by Nev, 27 November 2012 - 09:32 PM.
#1436
Posted 27 November 2012 - 09:39 PM
#1437
Posted 27 November 2012 - 09:45 PM
#1438
Posted 28 November 2012 - 08:27 AM
Just spoke to my mapper and we have a plan - hoorah.
I will wait for my honeycomb mesh to arrive from USA and install it in the 4" MAF (just before the sensor) and then hand the car over to him for approx a week so he can road dyno it and keep flashing the map until it's driving smoothly and fueling correctly.
At a guess I think it will probably end up running about 1.8 Bar of boost, thus leaving approx 5% to 10% duty cycle headroom for the 630cc injectors. Also, he will cure the over fueling at low revs and help reduce premature wear of the cylinders and rings.
However, we are going to need a rain free week... so it may be a while.
sounds good
I think I am at the limit now of my fuel injectors , which means new map + new FI.
#1439
Posted 02 December 2012 - 11:28 AM
#1440
Posted 06 December 2012 - 08:08 PM
Come on New :-) http://forums.seloc.....php?tid=349101
Hi Chris, I've signed up (donated) and am coming down for the morning.
I'm not even sure Nipper is safe to rev to the limit ATM, as I've changed the TB and tophat and know for a fact he was underfueling badly even prior to that, but the weather looks fine and I am keen to meet you for long chat (you might be interested in hearing about my next potential project).
See you Sat.
