Big Power Vxt Project
#161
Posted 12 December 2010 - 10:28 PM
Hopefully the CMS cast iron manifold will arrive tomorrow. I am growing nervous about this things ability to flow enough for my needs as the T2 flange on it may be a restriction...
#162
Posted 12 December 2010 - 10:33 PM
#163
Posted 12 December 2010 - 11:12 PM
#164
Posted 17 December 2010 - 09:47 AM
'Nev', on 12 Dec 2010 - 10:28 PM, said:
Picked up the Garrett GTX3071 turbo up today and also the enlarged throttlebody arrived in the post as well. Pics and info here
t2 is a bit tame, i thought that was only for the gt2876r ?
t3 by comparison
gtx3071r
#165
Posted 17 December 2010 - 07:07 PM
Anyway, I went into the garage tonight (brrrr...!) and took some pics of the manifold on a block with the turbo offered up...
Lots of juicy turbo pics HERE
#166
Posted 17 December 2010 - 08:27 PM
That's not fair. Tempt us with the promise of lots of juicy turbo pics and then give the wrong link.
Did you mean this link?
#167
Posted 17 December 2010 - 08:51 PM
#169
Posted 30 December 2010 - 06:30 PM
#171
Posted 30 December 2010 - 08:27 PM
'Duncan VXR', on 30 Dec 2010 - 6:30 PM, said:
Looks like it could work well nev. Any reason for not seperating the manifold face section to head? And was the location of ext wastegate selected on available space or design?
Looking forward to seeing it back together soon ;-)
Im not quite sure what you mean about separating the manifold face Dunc? Can you clarify?
The wastegate pipe position and length was designed so that the wastegate will point its exit downwards so that the pipe leading down from it can union with the outside edge of the existing exhaust pipe. I know its not ideal to union them on the outside bend as it will disturb the gases trying to get round the bend. If im lucky the guys who will weld it up for me may find space to get the pipes to join somewhere other than the outside edge of the curvature of the exhaust pipe.... we shall see. Alternately, I could be a very norty boy and vent the wastegate directly downwards to atmosphere (through a hole in the bottom of the aluminium floorpan). This would be make a very norty screamer pipe and be a bit MOT (and hearing!) unfrindly !! I don't like to think of the amount of noise this would make, just 12 inches behind the drivers seat with just 1mm of fibreglass as soundproofing !!
At least I can use a 44mm wastegate now, which should be able to vent a full bar of excess boost if I put a puny spring in the wastegate and only run 1.5 bar of boost.
Am hopeing to build up the engine in the next couple of weeks. All systems go - woohoo !
Have test mounted the new exhaust manifold on another block in the garage this evening. It fits (just) with a couple of spare mm between the block and the seemingly huge 71mm compressor housing.
As for completion dates.... hmmm... next Xmas ?!! LOL. Hopefully within 3 months realistically. Im a slow and patient worker, and now I have all the fiddly little unexpected fitting issues to deal with... first off will be buying and fitting the oil/water pipes to the turbo.... stupid turbos !
Edited by Nev, 30 December 2010 - 08:32 PM.
#172
Posted 06 January 2011 - 10:21 PM
#173
Posted 06 January 2011 - 10:30 PM
Edited by rob999, 06 January 2011 - 10:30 PM.
#174
Posted 06 January 2011 - 10:32 PM
#175
Posted 06 January 2011 - 10:35 PM
#176
Posted 06 January 2011 - 11:52 PM
Edited by Nev, 07 January 2011 - 12:02 AM.
#177
Posted 07 January 2011 - 06:43 PM
#178
Posted 07 January 2011 - 07:25 PM
#179
Posted 07 January 2011 - 11:06 PM
Edited by cheeky_chops, 07 January 2011 - 11:07 PM.
#180
Posted 08 January 2011 - 08:21 AM
Bing (2)
