It was indeed the same engine. Twin turbo 7L LSx hybrid. The engine was on a dyno stand and the owner was trying to find a decent ecu. Started at the cheap end as most of us do despite having spent out big time on the engine. It was some 15 years ago but from my vague memory it was checked at fixed RPM across a range (checked to see if it was a tickover issue). Some were proper ropey right over the rev range. Motec was by far the best we looked at.
Definitely interesting! Although quite some things have happened since 15 years...
I'm not sure it's really a matter of money in the end to be honest, how much money did you spend on the engine globally and on tuning the OE ECU ?
A mid-end standalone would have taken what, 15% of the budget ?
Well definitely my point of view.
Sometimes it´s incredible how much budget gets spent on OE mappings, additional TC systems, additional loging solutions, software to communictae with the OE ECU, external shift lights, external.....whatsowever.
In many cases, the sum of all turn out to be higher than a proper standalone system, which delivers all in one, and on a level which is simply not comparable to an OE ECU being tuned.
Further so many people just aim for max power figures (and then mainly the peak power).
It is soo much more important how driveable everything is ( as long as you donßt aim for 1/4, but definitely then another car then the VX should be chosen anyway).
It´s just such a huge difference how driveable a (properly tuned) standalone system is compared to an OE system. The boost control possibilities, electronic throttle response etc. etc. are soo different.
Not speaking about functions like Overrun Boost (Anti Lag) automatic downshift-blip, launch-control, wideband Lambda monitoring and control....
Not get me wrong nev, its not re your project but just in general.
it simply is that most of the times a OE controlled 400+ BHP are much less usable and resultingly quick, than some finely controlled 300ish.
But you will expereince it very soon, even if your ECU choice really is not the highest range one, it definitely will outgun the OE by far.
And everybody who tells me about the good driveability of a OE Turbo..... Well you should drive a properly mapped standalone and then tell judge again...
Since the stage 2 and now stage 3 with LEH, big air CC nothing is even near to having nice driveability sorry guys.
So resultingly said.
Definitely from my point of view a standalone should NOT be the last finishing step.
With a standalone unit you simply get out the best of ANY system. And what sense does it make to install parts, whichs potential will not be fully explored?
i think wast eof money Would prefer to maximise output and result of existing system.
But finally, its everybody´s choice.
Haha, guess that was now some standalone commercial stuff no?
OK, end off topic from my side.
BTW fantastic project Nev, especially having in mind that you come from a totally different corner!! (business-wise)
