Ball Joints - Delphi Tc163
Posted 09 January 2010 - 07:53 PM
Posted 09 January 2010 - 07:59 PM
Posted 09 January 2010 - 08:07 PM
Posted 09 January 2010 - 08:39 PM
Hi,
Purchased 8 ball joints for suspension refresh planned for spring time. Got the Delphi TC163's from a local motor factor.
On box it has the following: 'Opel / Vauxhall AK40D'
The 'AK40D' is also stamped on the bottom of the ball joint as well.
Has anyone else recent purchased this type of ball joint?
If so, could you confirm if yours had the AK40D reference on them.
Or what it the diameter of the correct sized ball joint?
Thanks
Kevin
The letters/numbers on the box and stamped on the joints are manufacturing batch numbers.
I've recently done all 8 of mine with Delphi joints from various batches without any issues.
HTH
Kevin
Posted 09 January 2010 - 08:52 PM
Hi,
Thanks
Kevin
May I ask what you paid for 8 Ball joints?
Posted 09 January 2010 - 09:29 PM
Posted 10 January 2010 - 05:25 PM
Posted 10 January 2010 - 05:56 PM
is this all u need for a suspension refresh?
If you go the whole hog do the bushes aswell. And as your removing those too then you may as well go and get the wishbones sand blasted and powder coated while there stripped down
Posted 10 January 2010 - 06:59 PM
Posted 10 January 2010 - 07:02 PM
Posted 10 January 2010 - 07:33 PM
Edited by joe_589, 10 January 2010 - 07:47 PM.
Posted 10 January 2010 - 07:47 PM
Posted 10 January 2010 - 07:50 PM
Posted 10 January 2010 - 07:52 PM
You'll probably need to get some new caster shims (which you can substitute for correct sized washers) and if you go with OE rubber bushes, you'll need to get some of the rubber coated snubber washers. Might be worth getting a handful of replacement nyloc nuts for the damper bolts and tie-rods (and track rod ends, if you don't replace them). Probably worth fitting the uprated Lotus 10.9 hub carrier bolts at the same time.
Posted 10 January 2010 - 08:32 PM
Thanks for all the replies.
I paid £9.59 each ex VAT from SC Motor Factors.
Total for 8 Inc VAT and a delivery charge to supplier was £94.56
Not a bad price for all 8 (as long as they are the right ones!)
Kevin
Do you have the part No. for the TRE's are the delphi or QH?
Cheers Oakmere
Posted 11 January 2010 - 01:16 PM
8 x ball joints TC163's / AK31C
2 x track rod ends
bushes - £140
4 x 10.9 hub bolts - where are these from?
sand and paint wishbones etc
lots of nyloc nuts - m8 or bigger/smaller?
Posted 11 January 2010 - 01:41 PM
Bought my last lot from Bell & Colvill4 x 10.9 hub bolts - where are these from?
Posted 11 January 2010 - 01:42 PM
Posted 11 January 2010 - 01:43 PM
