M32 And F23 Gearbox Options
85 replies to this topic
#21 slindborg
Posted 04 August 2010 - 09:09 AM
Yes tuthill are the folks I got to make me a near OEM setup, and then someone else had the time to get them to make it very OEM like but better quality :)
#22 vocky
Posted 04 August 2010 - 09:18 AM
you don't need new gear cables for the M32 conversion, the originals work perfectly fine you just need to loosen the end, turn it slightly and retighten it thumbsup
#23 slindborg
Posted 04 August 2010 - 10:59 AM
well the oem cables are sh**.... :lol:
#24 soupdragon
soupdragon
  • 691 posts
  • Interests:Revolution
Posted 04 August 2010 - 12:04 PM
But great news I don't have to get them for the box swap, there's enough bits to buy as it is
#25 chris
chris
  • 524 posts
Posted 04 August 2010 - 04:17 PM
Do you have some idea of the cost of Lotus 6 gear gearshift ? :rolleyes:
#26 soupdragon
soupdragon
  • 691 posts
Posted 05 August 2010 - 07:06 PM
:rolleyes:
Nope...is it necessary?
#27 FLD
Posted 06 August 2010 - 09:05 PM
Whats the weight difference between the two boxes? Is there any room for lightening ie could you machine off the rough casting marks on the sides of the gears to both smooth off to remove crack potential and lighten?
#28 siztenboots
Posted 07 August 2010 - 01:08 PM
only 4 hours to go , another JTS, this one is intact and driveable , v cheap http://cgi.ebay.co.u...=item3a5d7c9e74
#29 alanoo
alanoo
  • 1,324 posts
Posted 07 August 2010 - 02:47 PM
Different engine and gearbox on the 156, not the GM ones
#30 siztenboots
Posted 07 August 2010 - 03:58 PM
I think this is the 2.0l JTS gearbox 5spd , Top gear ratio 0.95, Final drive ratio 3.73
looks very similar to a 5 speed F23 as used on the Z20LET with the starter on the inlet side (rear)
		   2.0 JTS  /	3.2 V6 24v   / 	1.9 Diesel Mjet
No of Cylinders   	4			6				  4
Bore/Stroke (mm)	83/91		93/78			  82/90
Capacity (cc)		1970		3179		   	1910
Compression Ratio	11.5/1		10/1		   	18/1
Peak Torque (Nm)	206	 	289				305
Gear Ratios:
1st				  3.909:1	  3.5:1   	3.8:1
2nd				  2.238:1	  2.235:1	  2.235:1
3rd			 	1.520:1	  1.520:1	  1.360:1
4th			 	1.156:1	  1.161:1	  0.971:1
5th			 	0.946:1	  0.971:1	  0.763:1
6th					 		0.818:1	  0.614:1
Edited by siztenboots, 26 July 2012 - 10:12 AM.
#31 siztenboots
Posted 26 August 2010 - 01:16 PM
just found out the F28 6 speed box has same splines and clutch as the F23 for the LET with a FWD conversion plate 1st gear ratio: 3.57:1 2nd gear ratio: 2.16:1 3rd gear ratio: 1.45:1 4th gear ratio: 1.10:1 5th gear ratio: 0.89:1 6th gear ratio: 0.74:1 Reverse gear ratio: 3.23:1 Final drive ratio: 3.72:1 (front), 3.70:1 (rear)
#32 slindborg
Posted 26 August 2010 - 01:20 PM
F28's are twatting expensive, hard to get parts for (read impossible in some aspects), weigh as much as a VX and arent actually that strong :lol: So all in, I'd avoid.
#33 siztenboots
Posted 24 September 2010 - 02:39 PM
selespeed ratios Gear Type 5 Speed Selespeed Final Drive 3.56:1 1st Gear Ratio 3.80:1 2nd Gear Ratio 2.24:1 3rd Gear Ratio 1.52:1 4th Gear Ratio 1.16:1 5th Gear Ratio 0.91:1 i think its basically a robotised manual
#34 Nev
Posted 26 September 2010 - 05:50 PM
Excelent post and pics, is interesting to see how an F23 works internally. I wonder if anyone has had a straight cut set of gears made for the F23...
#35 iVXT
iVXT
  • 680 posts
Posted 26 September 2010 - 06:44 PM
Not seen any F23 straight cut gear kits but will prob be a way round it. Not sure if F20 would fit in vxt but that would open up loads of gear kit options.
#36 slindborg
Posted 26 September 2010 - 07:57 PM
an F20 Straight cut gearset would die on its arse with even a stage 1 terbow setup...... infact a regular helical set would be on its knees fast too. not to mention the F20 was NEVER cable shift, although converting to that cant really be that hard. Unfortunately with large torque, helical gears are the 'best' option, although if you can get the straight cuts wide enough you can get some of the torque handling back, but still lose power, so might aswell stay helical.
#37 FLD
Posted 26 September 2010 - 08:38 PM
Straight cut gears whine more than the missus. Not for everyday use if you ask me. I'd take the helical everytime.
#38 techieboy
Posted 26 September 2010 - 08:55 PM
:yeahthat:
#39 slindborg
Posted 26 September 2010 - 08:56 PM
a Sadev st170 box would be pure porn though lol
#40 iVXT
iVXT
  • 680 posts
Posted 27 September 2010 - 01:37 AM
Cable shift could be sorted with a different turret. Not sure what/if Quaife rate their gear kits up to but that's always a difficult thing as lots of variables.
Seen a few rally cars running f20 with decent power although most of these were dog boxes.
Gearbox stuff always tricky & costly though that I do know.
Cheers
P.S. Don't mind the whining from these boxes but agree not for everyday car.
