M32 And F23 Gearbox Options
85 replies to this topic
#41 siztenboots
Posted 27 September 2010 - 07:15 AM
more details about alfa options for 5spd
I think this is the 2.0l JTS gearbox 5spd , third and fourth all look good, Final drive ratio 3.73 so you would probably change that. Also seen on 147 1.6 T-spark, plus options from 145/146
Alfa 145 146 ratios
Transmission Ratios  1.4 T.Spark 1.6 T.Spark 1.8 T.Spark 2.0 T.Spark 1.9 JTD
1st Gear 3.909 3.909 3.909 3.545 3.800
2nd Gear 2.238 2.238 2.238 2.238 2.235
3rd Gear 1.520 1.520 1.520 1.520 1.360
4th Gear 1.156 1.156 1.156 1.156 0.971
5th Gear 0.919 0.971 0.971 0.946 0.763
Reverse Gear 3.909 3.909 3.909 3.909 3.545
Differential final drive pair 3.866 3.562 3.562 3.562 3.176
Number of teeth 15/58 16/57 16/57 16/57 17/54
                        2.0 JTS  /	147 1.6TS
No of Cylinders   	4
Bore/Stroke (mm)	83/91
Capacity (cc)    	1970
Compression Ratio	11.5/1
Peak Torque (Nm)	206
Gear Ratios:
1st              	3.909:1  	same
2nd              	2.238:1  	same
3rd             	1.520:1  	same
4th             	1.156:1  	same
5th             	0.946:1  	0.971
#42 soupdragon
soupdragon
  • 691 posts
  • Interests:Revolution
Posted 27 September 2010 - 07:45 PM
2 hours to go 156 2l JTS currently at £567
fleebay
Edited by soupdragon, 27 September 2010 - 07:46 PM.
#43 siztenboots
Posted 20 October 2010 - 11:47 AM
Getrag 6DCT250 , twin clutch dry system, electro actuation, rated to input 280nm
Bolted up to Fiat multiair 1.4 (note z20let starter position)
#44 siztenboots
Posted 20 October 2010 - 01:20 PM
Edited by siztenboots, 20 October 2010 - 01:22 PM.
#45 rapidos
rapidos
  • 224 posts
Posted 23 October 2010 - 11:05 AM
Does anyone of you know what Quaife gearbox is this one and to whom it's belonging please ?
#46 N17VES
N17VES
  • 560 posts
Posted 24 October 2010 - 08:40 PM
Does anyone have any measurements for the M32? Looking for alternative gearboxes in the exige....the alfa romeo close ratio box sounds interesting :)
#47 techieboy
Posted 24 October 2010 - 08:44 PM
If Vocky's experience is anything to go by, it's an expensive option as, they're very hard to track down. The more normal VXR M32 seems to be much easier to come by.
#48 N17VES
N17VES
  • 560 posts
Posted 24 October 2010 - 10:32 PM
Ratios are all wrong for an 8k+rpm though. The only other suitable option at present is the audi 6 spd box, but but the conversion is £4k fitted!! Thought the alfa box could be straight forward swap with an adaptor plate...
#49 siztenboots
Posted 29 October 2012 - 10:32 AM
M32 refurb
NP238750 99401 Shaft Bearing (Barcode 0 53893 98057 6) , this is 1 of 2
NP238750 99401 Shaft Bearing (Barcode 0 53893 98057 6) , 2nd of 2
NP854792 99401 Shaft Bearing (Barcode 0 53893 77011 6) (There are also 2 of these in the M32 so both pictured)
NP854792 99401 Shaft Bearing (Barcode 0 53893 77011 6) as you can see, this one is pretty knackered.
NP797735 99401 Shaft Bearing (Barcode 0 53893 60252 6) This was the main cause of the refurb
NP259742 90KM1 Input Shaft Bearing (Barcode 0 53893 77663 7)
So to summarize
1 x Input Shaft Bearing
NP259742 90KM1 Input Shaft Bearing (Barcode 0 53893 77663 7) X1
5 x Shaft Bearings
NP238750 99401 Shaft Bearing (Barcode 0 53893 98057 6) X2
NP854792 99401 Shaft Bearing (Barcode 0 53893 77011 6) X2
NP797735 99401 Shaft Bearing (Barcode 0 53893 60252 6) X1
and not pictured here
2 x Differential Bearings
NP537150 90KM2 Diff Bearing (Barcode 0 53893 77016 6) X2
#50 siztenboots
Posted 29 October 2012 - 10:34 AM
#51 Pidgeon
Pidgeon
  • 5,254 posts
Posted 19 September 2013 - 07:03 AM
Vauxhall Turbo Spares have offered me a box from an Astra GSi Turbo.  Can anyone confirm compatibility?
#52 siztenboots
Posted 19 September 2013 - 07:48 AM
gearbox code could be either a TR , or same as VX , the AF
#53 Munching Mike
Munching Mike
  • 211 posts
Posted 10 November 2013 - 05:27 PM
[font="'times new roman';"]Is there a gearbox swap, e.g., the Zafira 2.2 box, that will fit, without all the cogs having to come out, first?   I have limited mechanical ability…[/font]
#54 vocky
Posted 10 November 2013 - 05:46 PM
the zafira A - 2.2 box comes with a 4.17 and is a straight swap into the 2.2 vx220
the zafira A - z20let gearbox comes with a 3.95 final drive ratio and is a straight swap into a 2.0 vxT
Edited by vocky, 10 November 2013 - 05:47 PM.
#55 fezzasus
Posted 10 November 2013 - 05:48 PM
There are three manual transmissions in development by GM for use in Europe - this are 5 and 6 speed variants intended to address shift quality and save weight, using carbon fibre casing where possible. Should be available by 2016.
I assume these will mate to the Z22SE and Z20LET (because it would be daft to change the bell housing) so should create some more options.
#56 Munching Mike
Munching Mike
  • 211 posts
Posted 11 November 2013 - 10:50 PM
Thank you, both :)
#57 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 09 October 2014 - 08:06 AM
wanted to revive this thread, any update on information with regards to gearboxes? anyone found any nuggets out that? I would prefer one which said call this number for a m32 which has all the bits to fit the vx and at £800 I would like to have change mine and install a LSD
#58 techieboy
Posted 09 October 2014 - 08:11 AM
#59 NickB787
NickB787
  • 7,813 posts
Posted 09 October 2014 - 05:58 PM
I take it that's a no then....
#60 Kieran McC
Kieran McC
  • 3,416 posts
Posted 09 October 2014 - 06:11 PM
Quaife Lsd or a similar type is not recomended when a M32 box is fitted for rear wheel drive , Its fine on a Astra vxr front wheel drive. I looked at putting one on mine saved a few quid by not fitting one, Good luck Nick if you can do it for £800 Will be nearer 2k Europa gear shift and drive shafts new over 1.4k
Edited by kieranmcc, 09 October 2014 - 06:22 PM.
