Sealant
15 replies to this topic
#1 Kdan
Kdan
  • 110 posts
Posted 08 February 2010 - 03:20 PM
Right well it looks like ive made a right hash of my headlights, i originally took one out to change the bulb - no problem at all, i had a check around the seal and all was good, no gaps etc. I then took the other headlight out and noticed the whole bottom half of the lens coming away, enough so that i could lift it up and slide a £1 inbetween the gap! Seeing as i have a week off work i thought i would remove the lens on both lights, paint the insides black (i have a NA) and reseal using some decent stuff, first of all this is not an easy job, its a real PITA and i wish i had just resealed the bloody thing and not bothered I went to halfords and chose some clear silicone sealant which the packet stated "perfect for sealing light clusters" withstands extremes of temps etc. So i used this gear and left the lights indoors for 2 whole days with lots of clamps holding down the lens to apply pressure, fitted the lights and now 2 days after being on the car the whole bloody lens is coming away! there is a massive pool of water inside the light and i need the car for tomorrow so im in desperate need of some decent sealant - the car lives outside and for the time being i have taped alongside the light just to stop any more water getting in Ive heard that Tiger Seal is the gear to get however i can't find this in any shops, only seems to be online Can anyone reccomend a sealant fit for the job of sealing the lights? There is a B&Q and Halfords near me so a sealant which they stock - ive had a look and they have Loctite Superflex Sealant, is this any good? Sorry for the long winded post just to ask for a decent sealant :rolleyes:
#2 techieboy
Posted 08 February 2010 - 03:29 PM
Euro Car Parts does it (or a similar version) if you've got a branch close to you. Noticed it in my local'ish one a few weeks back.
#3 Kdan
Kdan
  • 110 posts
Posted 08 February 2010 - 03:42 PM
No joy im afraid, just gave my local branch a call and they have never heard of the stuff
How about this Loctite superflex sealant - its used to seal windscreens in so must be fairly hard wearing?
#4 techieboy
Posted 08 February 2010 - 03:47 PM
Must have been Sikaflex then. Certainly one or the other and basically the same stuff.
#5 Kdan
Kdan
  • 110 posts
Posted 08 February 2010 - 03:59 PM
So this Sikaflex is the same as Tiger seal? ive heard its the stuff to use for jobs like sealing headlights
Anymore recommendations? Ill have a look for this Sikaflex but ideally need something which is available in the shops - halfords, b&q etc
Thanks for the help thumbsup
#6 Retset
Retset
  • 1,766 posts
Posted 08 February 2010 - 04:16 PM
Loctite do a black sealant which worked fine for me and came from a local shop. Sikaflex easily available from ebay usually.
#7 Kdan
Kdan
  • 110 posts
Posted 08 February 2010 - 04:20 PM
Yeah i was looking at the stuff they do in Halfords, comes in a tube and therefore wouldn't require a gun to apply it
I have found SikaFlex EBT on the B&Q website, ive googled it and there are other various car forums saying they used that for resealing lights but it requires a gun
Which do i go for?
#8 Retset
Retset
  • 1,766 posts
Posted 08 February 2010 - 04:26 PM
Guns are cheap and do other stuff so that is not an issue. Loctite works fine though so if you can get it easily then job done.
#9 Kdan
Kdan
  • 110 posts
Posted 08 February 2010 - 04:31 PM
Just checked the garage and we have a gun, i just want to make sure i get the right stuff as these lights are a real pain in the arse and i dont want to be doing this all over again
Can you remember the type of stuff you used, was it Loctite superflex?
Do i go for Loctite superflex or Sikaflex, all these flex's are getting me confused :tumble:
#10 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 09 February 2010 - 10:38 AM
The loctite superflex (5940) stuff in a tube from Halfords should be fine. I used it to add a bead along my windscreen rubber seal. Headlights are on the list to get sorted when I get round to it. Q: Is Tigerseal/Sikaflex silicone sealant by a different name or special in some way? :unsure:
#11 Kdan
Kdan
  • 110 posts
Posted 09 February 2010 - 06:26 PM
Thanks for the help guys, im going to go for Sikaflex as ive been told it will do the job well and ive found some at B&Q thumbsup
#12 darronwall
darronwall
  • 2,706 posts
Posted 09 February 2010 - 09:33 PM
when mine did this i removed the lens with a stanley blade and replaced using black gutter sealant,job done!
#13 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 10 February 2010 - 10:52 AM
Tigerseal/Sikaflex are not silicone sealents. They are based on PU as opposed to silicon
Tigereal/Sikaflex-
  • One component ready for use polyurethane sealant and adhesive.
  • Will permanently seal and bond body panels and trim.
  • Can be used to seal around windows, doors and lights etc.
  • Once cured it can be over painted with most paint systems.
Leave silicon sealents for going around baths/showers/sinks!
#14 Ouchie
Ouchie
    Monkey no mates
  • 4,805 posts
Posted 10 February 2010 - 11:04 AM
thumbsup So Tigerseal/Sikaflex is a sealing adhesive, but silicon stuff is just a sealant.
#15 starlight
starlight
  • 1,790 posts
Posted 10 February 2010 - 11:07 AM
Exactly!
#16 Kdan
Kdan
  • 110 posts
Posted 11 February 2010 - 01:13 PM
This bloody Sikaflex and tigerseal is a nightmare to get hold of, i need this stuff quickly and therefore didn't want to buy it on ebay and wait for it to arrive I have however found some Purflex at a local car parts shop, its a polyurethane sealant so im guessing its pretty much the same stuff, ive googled it and it looks like it will do Anyone used it before and will it do a good job in sealing my headlights?
