Throttle Position Sensor
Posted 04 March 2010 - 09:22 AM
Posted 04 March 2010 - 09:27 AM
Posted 04 March 2010 - 11:53 AM
Could well be the connectors of doom inside the nearside rear wheel arch. They often turn out to be the culprit where throttle problems are concerned. It's a case of jacking the car up, removing the wheel and arch liner. Then attached to the header tank bracket (usually, although in FLD's case they were on the gearbox) are two connectors. Usual cure is to disconnect them, clean them up with some contact cleaner and make sure that all of the connectors make proper contact before reconnecting.
Also worth doing the same to the connectors on the throttle pedal and the throttle body.
Cheers
That'd make sense as it got the new front clam only last month so that are may well have been disturbed.
Posted 04 March 2010 - 11:56 AM
Posted 04 March 2010 - 12:51 PM
Thanks for the tip, I'll have a look at it on the weekend fingers crossed this sorts it. Quite scary pulling into a main road to then loose throttle.On mine the contacts open up. When you pull the plug apart look at the part with the female terminals. Pull of the yellow grid piece and examine all the terminals. You often find that one or two have opened up with the leverage from the wiring moving. Stick a safety pin in and tighten it up. Reassemble and off you go!
Posted 04 March 2010 - 01:40 PM
Tell me about it! I lost mine on the M6 a while back.
Posted 04 March 2010 - 01:44 PM
Posted 04 March 2010 - 05:57 PM
Edited by Denthrax, 04 March 2010 - 05:58 PM.
Posted 04 March 2010 - 06:26 PM
Posted 07 March 2010 - 06:05 PM
Posted 07 March 2010 - 06:17 PM
I didn't have time to investigate this weekend, but nights drawing out I'm hoping to have a look sometime this week. Any other tips anyone can offer, so I need to take nearside rear wheel off, remove arch liner, open connector, clean, check females are not splayed, if so tighten them up. Also look at throttle body connector, same thing really. I'm sure its connector / water / freezing weather related.
Regards contact cleaner, WD40 ok?
Had similar issues last year and it was the connector just above the throttle pedal. This link might help
Posted 07 March 2010 - 06:57 PM
Cheers
Anyone got any suggestions for the best contact cleaner to use?
Posted 07 March 2010 - 07:03 PM
Posted 07 March 2010 - 07:24 PM
I just use a can of Halfords finest Contact Cleaner and a fibreglass pen to clean the contacts up.
I'll pick some up on the way home
http://www.halfords....tegoryId_165750
and just ordered one of these, didn't know they existed
http://cgi.ebay.co.u...=item3ef65f0096
I was thinking along the lines of wd40 and a toothbrush
