Rockingham
280 replies to this topic
#241 Mystery
Mystery
  • 1 posts
Posted 29 April 2010 - 08:49 AM
Edited by Mystery, 29 April 2010 - 08:52 AM.
#242 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
  • Interests:Tech head
Posted 29 April 2010 - 08:55 AM
Indeed....
#243 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 29 April 2010 - 09:28 AM
What about the onions round your neck and garlic up your ar... oooeerrr missus.
garlic will be position in a better strategic area.....:P
garlic in the car bring good luck as well ;)
May bring good luck but will keep the chicks away...
#244 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 29 April 2010 - 09:38 AM
ye olde broken one is at the garage today, so hopefully I'll know what's up with it later.
#245 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 29 April 2010 - 09:39 AM
:yeahthat: remind me to buy some purple garlic at le mans:P
another two weeks and the car will be ready and i know i won't be near the soupacharged but will enjoy it B)
#246 techieboy
Posted 29 April 2010 - 10:10 AM
Not again? :o :(
#247 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 29 April 2010 - 10:11 AM
Checking out the smoke?
#248 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 29 April 2010 - 10:29 AM
Yeah, compression test as advised, general checking over to if they can see the problem and then go from there.
I really can't be doing with another big expense to put this right, so hopefully it's something simple.
Edited by AliM, 29 April 2010 - 10:33 AM.
#249 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 29 April 2010 - 10:45 AM
spare available ali just in case...... ;)
#250 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 29 April 2010 - 10:48 AM
have you got a spare low mileage 2.2 engine in your shed?
#251 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 29 April 2010 - 10:52 AM
at the rate i am going i will have 75% :lol:
will try to help you as much as i can
have faifth maybe it's only a little cough B)
#252 techieboy
Posted 29 April 2010 - 10:53 AM
Fcuksticks! Fingers crossed it's nothing nasty and is a quick, cheap fix. thumbsup
#253 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 29 April 2010 - 10:56 AM
Didn't look bad at all, just a puff of smoke when booting it after a time on idle. Does breathe heavily though for an NA.
#254 AliM
AliM
    insert humour here
  • 9,146 posts
I can still drive it and performance wise it seems ok, it's just guzzling oil and stinks!
#255 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 29 April 2010 - 10:57 AM
time to take it to vocky alim the guy makes wonder ;)
#256 techieboy
Posted 29 April 2010 - 10:58 AM
What grade oil are you using? Maybe it's just a bit too thin after the head work you had to have done.
#257 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 29 April 2010 - 11:00 AM
5w40 thumbsup
#258 techieboy
Posted 29 April 2010 - 11:13 AM
Not ultra ultra thin but still on the thin side of thick. Dunno. Getting into the realms of me not knowing what the feck I'm talking about. :unsure: Hope it's something as simple as that though. thumbsup
#259 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
Posted 29 April 2010 - 11:23 AM
Fingers crossed then. Shouldn't be anything too big if there's an issue... otherwise it probably wouldn't run :P
#260 AliM
AliM
    insert humour here
  • 9,146 posts
Posted 29 April 2010 - 01:43 PM
apparently there is a list of things they need to talk to me about :(
