Coupe?
81 replies to this topic
#41 smiley
Posted 22 November 2014 - 01:35 PM
The german mould sale also included the cat drawings of the hinges.
That french version however has some pretty flimsy versions of his own by the looks of it.
#42 Exmantaa
Posted 22 November 2014 - 07:28 PM
Did some investigation and this French guy apparently made his own coupe version, heavily based on the German shape. He mailed me some detail pics of the molding proces and they're quite interesting for possible other versions. thumbsup
#43 Kieran McC
Kieran McC
  • 3,416 posts
Posted 22 November 2014 - 07:33 PM
Are there any pictures of the hinge fitting ..?
#44 Exmantaa
Posted 22 November 2014 - 07:50 PM
Yes, lot less sophisticated than the German one... Will upload some pics in my gallery here
#45 Darcini
Darcini
  • 2,508 posts
Posted 22 November 2014 - 08:14 PM
Looks a similar solution to mine. Nothing complicated, a laser cut stainless steel U shaped hinge, bolted and bonded onto the roll bar cover with a pair of right angle brackets.
#46 Kieran McC
Kieran McC
  • 3,416 posts
Posted 22 November 2014 - 08:24 PM
Looks quite a easy fixing solution, just not sure about the right angled edges, I prefer the rounded ones on the German coupe.
#47 TFD
TFD
  • 607 posts
Posted 22 November 2014 - 08:33 PM
German one looks real good, but how about heat getting out of the car now the lid is closed?
#48 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 22 November 2014 - 09:30 PM
I must say the German one looks a poper solution, whereas the french one just seems to be yet another version that works when closed but horrid when open. Plus the German one must put far less load on the rollbar cover with the buttress extensions not being part of the 'lid'.
#49 Exmantaa
Posted 22 November 2014 - 10:06 PM
some French details:
#50 Exmantaa
Posted 22 November 2014 - 10:13 PM
Actually the shaping and making of this looks not that difficult. Only to get it really looking right is an art and it's all in the details.. :unsure:
To me the rears should curve a little more inwards and the rear flat is a bit too thick and should be level with the clam rear like the normal bootlid.
Edited by Exmantaa, 22 November 2014 - 10:14 PM.
#51 Exmantaa
Posted 22 November 2014 - 10:26 PM
See the subtle differences with the German version:
#52 FLD
Posted 23 November 2014 - 10:45 AM
I agree.  The French one doesn't follow the outer curve of the buttress.  The hinges are what weigh on my mind the most.  Both of these bolt in with the roll bar cover bolts but I'm concerned that the bulkhead material is quite soft and the hinges have quite some leverage against it.  Its this reason I went the Darcini method with mine but I'm still not entirely sure about that either which is why it still isn't fitted!  I think the ultimate method has to be similar to gingerjons with use of the exige hinges.  I've started moulding a new roll bar cover with bosses moulded in for the hinges.  In my head this has to be done right.
#53 2-20
2-20
  • 1,317 posts
Posted 23 November 2014 - 05:42 PM
It's a pity
So much work involved with this copy and not being able to copy right.
Even the distance beetween each "flap" looks weird ....
#54 Exmantaa
Posted 23 November 2014 - 06:10 PM
It's not that he did not had some decent inspiration nearby :happy: :
But to be honest this looks more decent than some other mad creations I've seen passing by...
#55 Baron Von Scubadaddy
  • 6,644 posts
Posted 23 November 2014 - 07:13 PM
Put me down for one of those please luv .
#56 FLD
Posted 23 November 2014 - 07:34 PM
 Happy with a grp one?
#57 Baron Von Scubadaddy
  • 6,644 posts
Posted 23 November 2014 - 07:38 PM
yeah !
#58 smiley
Posted 23 November 2014 - 08:00 PM
Is that where the ducktale story end?
Bummer. Really looked forward to something different.
#59 2-20
2-20
  • 1,317 posts
Posted 23 November 2014 - 08:41 PM
The use of rose joint on the french copy  is clever , you have less alignment troubles
#60 gingerjon
gingerjon
  • 587 posts
Posted 23 November 2014 - 09:58 PM
It's nice to see other peoples solutions to this!
I'm happy with mine in theory but my my lack of skills in the GRP area have let me down on the finish. Matt has answered plenty of questions to help get where i am now. I need to trim the edges where the rear meets the new Roll Bar i made and also need some angle Alu block to keep the brackets attatched in the right way.
Not done a lot on mine since i got it to the "it fits and works...sort of" point.  With Matt using the same hinges and having infinately more experience i am hoping it will come together eventually! Moving house this week....will finally have a garage!!! So Makes GRP work a little eeasier as i can do it in the evening rather than only at the weekends
Or i'll just buy one from Matt! :ninja:
Edited by gingerjon, 23 November 2014 - 09:59 PM.
