Pro Alloy larger alloy fuel tank
Covered approx 15k in full working order and as new
£500 - RRP £611
Details from Pro Alloy Web Site;
VAUXHALL VX220 TURBO/NA FUEL TANK (LARGE CAPACITY)
High Capacity Anti Surge Alloy fuel tank for VAUXHALL VX220 TURBO/NA/OPEL SPEEDSTER
Anybody running a high powered Elise /Vx/Vxt on track will know that the standard tank arrangement allows the fuel to surge when making left hand corners- this can be a big problem on high revving or turbocharged cars where weak fuelling can cause terminal engine damage.
Developed and tested on our own trackday cars, our long range Alloy tank allowed us to run right down to 3ltrs without surge.
Features..
*48 ltr capacity (standard 38 ltrs)
*Internal collector assembly installed with Anti surge check valves.
*Safety foam Type IV FIA polyether
*Light weight alloy construction weighing 6.65k (standard 10.8k)
*Alloy construction will not corrode like the standard steel tank
*Utilises Standard fuel pump and sender unit
*Eliminates the need for external fuel swirl pots and collectors
*Simple installation using all original fittings and brackets
*Circlip flange Accepts standard pump assembly
Can offer fitting if required
Pro Alloy Larger Baffled Alloy Fuel Tank
Started by
Duncan VXR
, Jun 01 2010 11:41 AM
1 reply to this topic
