Ecu Removal Help!
Posted 07 June 2010 - 04:20 PM
The strange thing is only 1 is a security screw the other seems to have no head.
How the hell do I get this thing out?
Any ideas?
Posted 07 June 2010 - 04:22 PM
Posted 07 June 2010 - 04:24 PM
drill it out
I thought that might be the case
Just spent fookin ages wondering why the clips wouldn't release!!
Edited by james141, 07 June 2010 - 04:24 PM.
Posted 07 June 2010 - 04:28 PM
Posted 07 June 2010 - 04:30 PM
If you remove the anti tamper torx on the right, you can then move the plate back and forwards which will then losen the l/h shear bolt
Ok thanks, im guessing the bolts holding the ECU in the car are under this plate too?
Posted 07 June 2010 - 04:35 PM
Edited by vx220nelly, 07 June 2010 - 04:36 PM.
Posted 07 June 2010 - 05:18 PM
Posted 07 June 2010 - 05:20 PM
Posted 07 June 2010 - 05:49 PM
just drill it! there is nothing you can damage! unless you are go serious off course with a drill bit
Yeah problem is I don't have a drill
Need to borrow one
Posted 07 June 2010 - 05:54 PM
Posted 07 June 2010 - 05:58 PM
Posted 07 June 2010 - 06:02 PM
James have you tried moving the bracket and ecu with the front bolts out aswell ? worth a try brfore you go get the drill
I couldn't see the front bolts I believe they are under that plate
Posted 07 June 2010 - 06:03 PM
I used a dremel with a cutting disc to cut a slot, then just a screwdriver
I might give that a try tomorrow only problem is I have a cheap copy dremel so it might not be man enough
Posted 07 June 2010 - 06:13 PM
So long as you have a mains powered one it should be fine - might want to get someone else to hold the cables put of the way - MrSimba was my volunteer!
Posted 07 June 2010 - 06:14 PM
Edited by joe_589, 07 June 2010 - 06:14 PM.
Posted 07 June 2010 - 06:21 PM
Posted 07 June 2010 - 06:31 PM
ECU Front bolts
I have got those two out are there two more at the top?
Posted 07 June 2010 - 06:33 PM
Posted 07 June 2010 - 07:04 PM
4 including the two security ones at the top?Only four bolts in total
Posted 07 June 2010 - 07:07 PM
