Pictures Of Steinmetz Or Similar Grill
13 replies to this topic
#1 Paulus H
Paulus H
  • 2,063 posts
Posted 08 June 2010 - 09:14 PM
I have removed my plastic V.
I am interested in fitting a Steinmetz (or similar) grill now the dreaded V is gone.
Does anyone have any clear pictures of the Steinmetz or similar??
Above is picture of V removal. Basically the V is attached by self tapping screws that screw into the V from behind the grill. Therefore the only options are to remove the clam and remove the screws or destroy the grill so the screws do not have anything to screw into.
My approach was to attack the V with a hole saw to remove the majority of the material. Then I removed the last parts of plastic that were still attached to the retaining screws. I removed the last of the plastic with the side cutters. The retaining screws fell behind the grill and the virgin grill was revealed.
Edited by Paulus H, 08 June 2010 - 09:19 PM.
#2 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 08 June 2010 - 09:23 PM
http://cgi.ebay.co.u...=item1c049eef5b chinky chinky
#3 fiveoclock
fiveoclock
  • 9,453 posts
Posted 08 June 2010 - 10:29 PM
#4 yaaan
yaaan
  • 956 posts
Posted 09 June 2010 - 09:12 AM
Having been down to BOT for sevice and MOT I find that the last owner who I thought had done nothing to the car has infact fitted one of these (or a copy as the Steinmetz badge is missing) and also discovered he'd uprated the front and rear engine mounts. Shame he didn't to the left and right as they were completely fooked!
#5 styles
styles
    Thunder Lips
  • 2,697 posts
  • Interests:Running the VX on a £5'er..... :-P
Posted 09 June 2010 - 10:33 AM
You dont uprate the left and right mounts. Just replace when they go, like yours have. thumbsup They should now last longer with the powerflex inserts you have.
#6 yaaan
yaaan
  • 956 posts
Posted 09 June 2010 - 12:52 PM
... when they go, like yours have. thumbsup
They had both split in half....good job I'd bought the new ones :lol:
#7 slindborg
Posted 09 June 2010 - 01:02 PM
so in short you had/have no idea what you were/have purchased.... well investigated there :lol:
#8 yaaan
yaaan
  • 956 posts
Posted 09 June 2010 - 02:12 PM
Well that's a bit extreme but not far from the truth :lol: Checked most of the main things and it's sound (apart from the sied engine mounts!) but bought it from a dealer who didnt have much of a clue. To be fair though I've never taken the undertrays off before so never knew about the uprated engine mounts :)
#9 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 09 June 2010 - 07:40 PM
I like your style B) :lol:
#10 Wolfstone
Wolfstone
  • 12,987 posts
Posted 10 June 2010 - 07:40 PM
Buy a Steinmetz replica from Sam (SPLAM on the forum) and save youself a fortune. The Steinmetz is about £400 and Sam's replica is £155. Here's a pic of Sam's just fitted 4 weeks ago. And you don't have to remove the front clam to fit which you do with the Steinmetz. I've also just added VX220 and Turbo badges to his grille to give it a slightly different look.
#11 Paulus H
Paulus H
  • 2,063 posts
Posted 10 June 2010 - 09:49 PM
Mmm that's why I wrote, "or similar". I was looking for the general Steinmetz style. Yeah I think I'll go for the SPLAM style. I have not seen a clear picture of the splam grill previously. I was hoping it looked half as good as your picture!! Many thanks for your reply. One question though, how did fitting go???? Best regards, Paul
#12 Wolfstone
Wolfstone
  • 12,987 posts
Posted 10 June 2010 - 10:04 PM
Best regards, Paul
You're very welcome. chinky chinky
The quality of Sam's grille really is excellent. Can't speak highly enough of it. Imnotworthy
I had my front end re-sprayed at the same time so the body-shop fitted the grille. But they're a piece of p*ss apparently to fit. They attach to the original VX mesh grill using a rubber type rawl nut that pushes through the original grille and then, using a small allen key, tightens up and holds it in place.
Here's a better picture of the attachments.
Ken
#13 Guest_VX220Dallan (Guest)
Posted 11 June 2010 - 10:03 AM
haha this picture looks like you havent got any wheels!!
#14 Wolfstone
Wolfstone
  • 12,987 posts
Posted 11 June 2010 - 08:46 PM
:lol: That's what happens when you live in Milton Keynes! Turn your back and some chav nicks your wheels.
