As above, where is the coolant bleed valve on an NA? Just had my heater box out (more on that later...the joy) and now it will obviously need topped up and bled!
Thanks!
Chris
Where Is Coolant Bleed Valve, Quick Help Needed!
Started by
hutchy
, Jun 09 2010 02:32 PM
6 replies to this topic
Posted 09 June 2010 - 02:32 PM
Posted 09 June 2010 - 02:34 PM
Thanks!
Chris
on the passanger side pipe, connected to the rad
Posted 09 June 2010 - 02:35 PM
The bleed nipple for the rad is located on the pax side of the rad. It's easily got to if you remove the pax light. There is probably another bleed point somewhere else.
Posted 09 June 2010 - 02:39 PM
And two bleed valves on the coolant pipes in the engine bay (between left-rear corner of engine and the boot)
Posted 09 June 2010 - 03:26 PM
Lovely, thanks! CBA taking light off TBH think I'll bleed from the engine bay unless anyone thinks thats crazy?
Posted 09 June 2010 - 03:29 PM
Actually scrap that! After I recognised the two valves at the back feeling in for the one at the front was no problem! Thanks guys you are life savers!
Posted 09 June 2010 - 04:09 PM
Make sure you do it up nice and tight. It's the most likely to weep.
Although doing it up too tight may make it weep too.
Good luck.
