13 hours has seen:-
both clams off
towing bracket sand blasted ready for painting
radiator cover off
large charge cooler installed
fans wired in
pipes run down the sills
new altenator put on
new injectors wired up
loom is in pieces ready for wiring
fit the top hose
re-routed the fuel pipes
installed manifold (temp)
installed charger (temp)
etc etc
basically everything is pretty much done bar the extention of some of the loom and the header tank installed (i dont have it yet)
but i was wondering if you could help me on a couple things.
1. what goes on the nipple here?
2. does this go back into the intake pipe?
3. where does this now go?
i think for now thats all i need to know to get it finished..
Edited by chris_uk, 15 June 2010 - 09:12 PM.
