B204 Saab 2.0l
14 replies to this topic
#1 siztenboots
Posted 22 June 2010 - 10:44 AM
what is the pattern for the gearbox housing, does a F23 bolt on? the 90 mm bore and 78 mm stroke is quite interesting for some high rpm :) plus a holset hx40 :)
Edited by siztenboots, 22 June 2010 - 10:57 AM.
#2 Winstar
Winstar
  • 4,264 posts
Posted 22 June 2010 - 10:57 AM
It should be GM, a few people have attached the 2.3 version to an Omega box for RWD cars.
#3 siztenboots
Posted 22 June 2010 - 12:17 PM
depending on the back to front layout and packaging , it should make for a very capable 600+ hybrid griffin :) map the Trionic yourself directly with this: http://trionic.mobixs.eu/
Edited by siztenboots, 22 June 2010 - 01:13 PM.
#4 siztenboots
Posted 22 June 2010 - 01:21 PM
"chip" from vauxsport.com Nova C20let to B204
looks like a ttv flywheel , and a GM pattern housing
Edited by siztenboots, 22 June 2010 - 01:22 PM.
#5 slindborg
Posted 22 June 2010 - 01:24 PM
ohhh yeah, I remember hes doing that swap now after cracking his LET block with uber boosts :) Check his charge cooler out.... 17Litres capacity :lol:
#6 siztenboots
Posted 23 June 2010 - 11:14 AM
check out this baby Holset HX40 on the left , GT3076 right
#7 Winstar
Winstar
  • 4,264 posts
Posted 23 June 2010 - 11:40 AM
LOL that looks familiar
Does he say what the nomenclature is? HX40 is just the bearing housing size.
*Looks like a C86*** impeller at a guess
Edited by Winstar, 23 June 2010 - 11:41 AM.
#8 alanoo
alanoo
  • 1,324 posts
Posted 23 June 2010 - 11:43 AM
The problem is you just put high RPM and F23 in the same post... and unfortunately the F23 is really poor for high rpm applications
#9 siztenboots
Posted 23 June 2010 - 12:41 PM
is that because of the syncro's?
#10 alanoo
alanoo
  • 1,324 posts
Posted 23 June 2010 - 12:48 PM
No just because the gear ratios sucks and even if you fit the extra short 4.41 FD, the ratio themselves still suck... :groupjump:
#11 siztenboots
Posted 29 September 2010 - 09:15 AM
i agree, just changing the gearing is waste of time, I might as well just bolt on 15" wheels.
model year information for donor vehicles and differences between ecu
MY 94-98 (ng900)
B204L - 185hp, T25 turbo, non-x-flow IC - Trionic 5 (HOT)
MY98 (og9-3)
MY99
B204E - 154hp, T25 turbo (lacks MV), non-x-flow IC - Trionic 5
B204R - 200hp, T25 turbo (strengthend WG actuator), x-flow IC - Trionic 5 (HOT or just R)
B235R - 230hp, TD04 turbo, x-flow IC - Trionic 7 (Viggen)
MY00
B204E - 154hp, T25 turbo, non-x-flow IC - Trionic 5
B205L - 185hp, GT17 turbo, x-flow IC - Trionic 7 (HOT)
B205R - 205hp, TD04 turbo, x-flow IC - Trionic 7 (Aero)
MY01->
B205E - 154hp, GT17 turbo, x-flow IC - Trionic 7
Difference between Trionic 5 and 7 is mainly the MAF which the T5s don´t have and the B2x5-engines are of a "low friction" type, ie other pistons and cylinder walls (pistons typically less sturdy due to thinner material).
T25 and GT17 are Garrett turbos, TD04 Mitsubishi.
The B204E lacks the Magnetic Valve that controls boost, it runs on base boost only.
Difference between B204L and R are WG actuator, IC and ECU.
From this you can learn: the first 2 digits denote deplacement in litres 2.0 or 2.3, the last digit stands for engine family 4 being trionic 5 and 5 being trionic 7
#12 Winstar
Winstar
  • 4,264 posts
Posted 29 September 2010 - 09:41 AM
I thought the T7 switched to FBW throttle?
#13 siztenboots
Posted 29 September 2010 - 09:44 AM
yes T7 means AMM and FBW and black direct ignition cassette
Edited by siztenboots, 29 September 2010 - 09:45 AM.
#14 siztenboots
Posted 29 September 2010 - 10:22 AM
Heads (info taken from UKSaabs) T7 The only two versions of the T7 head involve the exhaust valves AFAIK: one version (the low power version) has plain stainless exhaust valves, and the other version (high output) has Nimonic 80A superalloy exhaust valves. In later years, the low-power head also got the Nimonic valves, but there are still two part numbers because of the earlier, outdated, head. There are also two inlet manifolds- one for the B235R, one for the other engines. The B235R's intake manifold appears larger, and lacks the strainer (which restricts flow) on the other models beneath the throttle body. The T5 throttle-body appears to mount to the B235R T7 intake manifold, as Vigge has actually done this. However, the T5 throttle body requires a T5 delivery pipe and transition casting to match. The T7 head has lighter valve-springs because it has lighter valves: the stems are thinner. (about 5mm diameter) That means the valve guide openings are also smaller, etc. Thinner valve-stems = more gas flow and less need for tight springs.
#15 siztenboots
Posted 01 October 2010 - 08:00 AM
looking at engine mount positions, it has a sort of swing arm torque damper and a similar back under gearbox central mount
