The DVLA web site lists the following MOT advisories from just a few months a go. Is there anything I should be worried about? It strange it's had so many advisories with such a low mileage - does it indicate it's been tracked?
Advisory Notice issued
Front also corroding Brake disc(s) (3.5.1h)
Rear also corroding Brake disc(s) (3.5.1h)
Nearside inner Track rod end ball joint has slight play (2.2.B.1f)
Offside inner Track rod end ball joint has slight play (2.2.B.1f)
Service brake Your vehicle has only just met the required service brake efficiency. It would appear that the braking system requires adjustment or repair. (3.7.A.9)
Some corrosion over the front and rear steering and suspension components
Both front tyres perishing, splitting and wearing on the inner edge
Unable to view the under bonnet fuel and brake lines fully
Unable to view the front to rear fuel and brake lines fully
Front tyres perishing and splitting, as already said, sounds like its had little use and certainly not a lot of track use unless they used track wheels.
Occasional use on a track is not going to ruin a car, depends on how its driven, some cars get enough abuse on a public road.
I wouldn't worry too much about any of those advisories, some MOT testers love to write loads of advisories, some dont. Its easy to advise that a component has corrosion on it unless its new.
Regarding the comment "loads of paint." This is where you need someone to inspect the car, needs to be someone who is familiar with a VX, plenty of people on here who may do it for beer money, could be the best few quid you will ever spend.
Repainting is common on these cars, probably not many 8 year old VX's that are still on their original paint. An expert will tell you whether its a satisfactory paint job or not.
A sports or prestige car with no service history is a shame, it will be difficult to resell. I dont know how any car dealer can sell a car with no history and then stand by the mileage, call me fussy if you like, but I would not retail a car to the public without being able to guarantee the mileage, because they can come back at you later if its found to be incorrect and trading standards would have something to say.
Sorry to waffle, golden rule number 1, your spending a lot of cash, get the car looked at by one of our VX member anoracks, you will find ORG a very helpful and friendly bunch.
Edited by Tfp, 28 June 2010 - 04:20 PM.
