Battery Light Stuck On
Posted 15 July 2010 - 08:13 AM
Posted 15 July 2010 - 08:25 AM
Posted 15 July 2010 - 08:26 AM
Posted 15 July 2010 - 08:29 AM
Posted 15 July 2010 - 08:40 AM
Posted 15 July 2010 - 09:06 AM
Light is driven by a trigger output from the alternator, saying the alternator is not working.
Not quite correct. The light is illuminated when you first turn the ignition on from the 12v from the battery. Once the vehicle is started the altornator sends 14v the other way down the wire with the light. 2 positives cencel each other out and extinguish the light.
Edit: good idea on the garage thing. Nip it into one and ask them nicely
Edited by zoobeef, 15 July 2010 - 09:07 AM.
Posted 15 July 2010 - 09:01 AM
Posted 15 July 2010 - 09:04 AM
Posted 15 July 2010 - 09:21 AM
Will do that!
Could any of the wiring near the alternator have got damaged when you fitted the charger? I know it get's pretty tight down there
Shouldn't be, as I replaced the problematic wire
Posted 15 July 2010 - 09:58 AM
Edited by simsy, 15 July 2010 - 10:13 AM.
Posted 15 July 2010 - 10:01 AM
Posted 15 July 2010 - 10:08 AM
Edited by simsy, 15 July 2010 - 10:14 AM.
Posted 15 July 2010 - 10:13 AM
How long ago was the conversion? But I bet the alternator has
1\ stopped working due to an internal fault, over heated or shorted out. 3/10
2\ has a loose or damaged cable, easy fix if you could see the connections, which is not easy with a sc vx... 5/10
3\ Poor earth cable some where maybe. 2/10
if belt had snapped you would know, right.... no power, no sc song, steam, red light etc
It was a few months ago, and I've done over 3500 miles since that.
The belt definately hasn't snapped!!
Posted 15 July 2010 - 10:16 AM
Posted 15 July 2010 - 11:45 AM
Posted 15 July 2010 - 12:14 PM
Posted 15 July 2010 - 01:32 PM
Posted 15 July 2010 - 04:04 PM
Posted 15 July 2010 - 04:10 PM
