Battery Light Stuck On
22 replies to this topic
#21 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 15 July 2010 - 04:11 PM
Battery light on, ABS light on, Airbag light on, 'oh sh*t'. Wiper went halfway across windscreen and almost stopped after I flicked it once.
Got it to jamsport as I was about 15 minutes from home.
10.4 volts while running, surprised it actually was still running at that as well! In the 10 seconds I had it connected up it went to 10.2 so was dropping quite quickly!!
They're checking it out as I have no time to be playing right now, way too busy at work. I'll know tomorrow morning whether it's alternator or just a cable.
Well it certainly ain't charging then.... Hopefully a cable for you, but mine was the alternator that was fried.
Suppressor FLD I would doubt having an effect.... All that seems to do is smoothen out the delivery of the alternator into a more DC style current (rather than the peaks that occur when the magnet flies past the wire cores). I could however be wrong (having read my way through an article on HonestJohn and ShitiPedia.
#22 Seb.F
Seb.F
    Under Your Bed
  • 6,045 posts
  • Interests:Tech head
Posted 15 July 2010 - 04:17 PM
So next thing would be to see how many volts are at the altornator as that would tell you if its still working or if its a break in the wire
Indeed, I asked them to fire it up on another spare battery and check that while it's up and running thumbsup cheers
#23 vocky
Posted 15 July 2010 - 04:39 PM
either the small plug has fallen off or the alternator is fried :(
