2 Post Lift Jacking Points ?
12 replies to this topic
#1 Shmern
Shmern
  • 141 posts
Posted 20 July 2010 - 08:40 PM
Just fitted replacement OEM secondhand suspension to the car (Thanks JimmyJam!) Went to my mates garage, intending to use his lift, but it's a 2 post lift with the 2 swing arms, I wasn't comfortable jacking anywhere but the recommended jacking points so we ended up changing suspension on the deck with a normal trolley jack, as an aside, suspension is sooooo easy to change ! Anyway the question is, car you use a 2 post lift to lift a VX ? and if so how ?? I've searched and waded through LOTS of posts but haven't found anything :( Thanks Shmern
#2 2.2_na
2.2_na
    No Compromise
  • 6,323 posts
Posted 20 July 2010 - 08:48 PM
Jacking points http://wiki.seloc.org/a/Jacking_points
#3 styles
styles
    Thunder Lips
  • 2,697 posts
  • Interests:Running the VX on a £5'er..... :-P
Posted 20 July 2010 - 08:49 PM
Rear sub frame and at the front of the tub. If you remove the undertrays you will see where the safe points are. Edit: too late. Seloc wiki tells all :lol:
Edited by styles, 20 July 2010 - 08:51 PM.
#4 VIX
VIX
  • 9,497 posts
Posted 20 July 2010 - 09:35 PM
No doubt a post about brake pads will follow shortly ... :rolleyes:
#5 Shmern
Shmern
  • 141 posts
Posted 20 July 2010 - 09:37 PM
Thanks guys, but can i confirm something, on a 2 post ramp should i be using Points A and B to lift the car (A being the normal jacking points?),
now i haven't tried this, but my initial feeling is it might be slightly unstable towards the back of the car, as point A is almost a balance point when using a trolley jack, therefore using point B will support the car from tipping forward, but is there a risk tipping backwards towards engine bay ?
BTW the 2 post lift is like this
thanks for advice (in preparation of further work!)
Shmern
#6 styles
styles
    Thunder Lips
  • 2,697 posts
Posted 20 July 2010 - 09:40 PM
Go to any garage, back on track, courtenays etc and they use those type of lifts without an issue. Don't worry it's perfectly stable
Edited by styles, 20 July 2010 - 09:41 PM.
#7 Shmern
Shmern
  • 141 posts
Posted 20 July 2010 - 09:45 PM
Thanks, but being in Northern Ireland means I haven't the chance to goto those garages :) . Glad to hear it's stable, thankfully it was an easy job to change all the suspension, so doing it on the floor was not a big problem, but from now on I'll be using the Lift :)
Thanks
Shmern
#8 Winstar
Winstar
  • 4,264 posts
Posted 20 July 2010 - 09:49 PM
Shmern
you should be using points B and C for a 2 post lift. I've heard of A being used but with balast on the front bonnet!
#9 Shmern
Shmern
  • 141 posts
Posted 20 July 2010 - 09:58 PM
Aha ! I was thinking that!, only thing was would the arm extend enough into C and does the tray need removed for C ?
Shmern
#10 smiley
Posted 20 July 2010 - 10:08 PM
Be carefull with those 2 point jacks
Source: http://www.my914-6.com/crap
#11 Shmern
Shmern
  • 141 posts
Posted 20 July 2010 - 10:30 PM
See now your just scaring me :)
Shmern
#12 kipper
kipper
  • 2,364 posts
    Smoking various types
    of fish.
Posted 21 July 2010 - 09:18 AM
You will certainly need balast placed over the radiator, in the region of 40 lbs or more
otherwise there is going to be problems with the car tipping backwards off
the lift. Also when placing the wheels back on, afix the fronts first to give extra weight
over the front before attaching the rears.. This is from a recent experience.
Dave
Shmern
#13 siztenboots
  • 26,613 posts
Posted 21 July 2010 - 09:22 AM
thing is with the two post the rear arms are right on the tipping balance point. If you remove a front wheel , that balance is enough to make it go. hence some garages will hang a counter weight from the front of the car, just in case.
