Edited by soupdragon, 10 April 2011 - 11:27 PM.
Something Different !
#221
Posted 10 April 2011 - 11:25 PM
#222
Posted 10 April 2011 - 11:31 PM
#223
Posted 11 June 2011 - 08:26 PM
#224
Posted 13 June 2011 - 06:21 PM
This thread has been an incredible read over the months and the result is one brilliant vx
@ moneyhunter - The GM LS lumps are a compact modern pushrod V8, not sure they are compact enough though
I'll have an LS7 please, where do I sign?
Wouldn't the LS7 mean the car would have to be made a bit longer with a new subframe? What gearbox would you use?
Can u imagine looking at a LS7 under the boot mesh
LS7 looks boring with all its plastic covers on
You could probley fit one of the new crate engines into the original space with enough £££££s but you would have to get rid of the serpentine belt setup and mod the timing chain cover.
Sam.
#225
Posted 13 June 2011 - 06:46 PM
HI,
Just wondering as I'm new in the country (moved from Sydney... not for the weather!); how do you get to put a carb engine in a late model car?? what are the laws relating to which year engine/vehicle combo you can use?
Also, to the OP, did you keep any templates for the engine mounts and gearbox/engine adapter plate?
Hello,
Any car is MOT,d to whatever is the oldest, the chassis or the engine.
Pre August 1st 1992 is the cut off point, so if you put a 1986 Rover V8 engine into a say 2005 car and it will be MOT,d to 1986 Rover V8 emissions come MOT time.
Same goes if you put a 2005 engine into a 1986 car, it will then be MOT,d to the 1986 car emissions so no CAT needed on the new engine to get through MOT emissions.
I,ve been told you can use upto august 1995 engines to if it was never used in the car by the manufacturer but i carnt confirm if thats correct from experience
There was no templates for the engine mounts, i belive my uncle got his m8 to map out the gearbox/engine adapter into his cnc something or other incase we needed another one as it was time consuming thing to make but im not 100% certain of that
Sam.
#226
Posted 13 June 2011 - 07:22 PM
HI,
Hello,
I,ve been told you can use upto august 1995 engines to if it was never used in the car by the manufacturer but i carnt confirm if thats correct from experience![]()
There was no templates for the engine mounts, i belive my uncle got his m8 to map out the gearbox/engine adapter into his cnc something or other incase we needed another one as it was time consuming thing to make but im not 100% certain of that![]()
Sam.
thanks Sam. Great info.
If your uncle has a CNC template.. I'd be happy to buy a copy of the CNC file; or the actual adaptor...
I'm also wondering how the gearbox input shaft/spigot bearing was handled? Also the clutch/pressure plate/flywheel?
#227
Posted 17 June 2011 - 09:59 PM
#228
Posted 17 June 2011 - 10:28 PM
Edited by ChrisS1, 17 June 2011 - 10:28 PM.
#229
Posted 17 June 2011 - 10:38 PM
#230
Posted 26 July 2012 - 10:27 PM
Anybody know of a useable N/A rear clam with very light damage for sale in N/W kent area and a passenger side rear N/A light please ?
Hit by a vauxhall corsa hire car in the middle of nowhere
Still it was about time we took the clam of for a checkup of things
Edit: She drove it home 20miles like that too
Edited by Ground Effect, 26 July 2012 - 10:29 PM.
#231
Posted 26 July 2012 - 10:30 PM
#232
Posted 26 July 2012 - 10:36 PM
Edited by ben922, 26 July 2012 - 10:36 PM.
#233
Posted 26 July 2012 - 10:43 PM
#234
Posted 26 July 2012 - 10:45 PM
#235
Posted 26 July 2012 - 10:48 PM
#236
Posted 27 July 2012 - 06:42 AM
#237
Posted 27 July 2012 - 08:44 AM
#238
Posted 27 July 2012 - 08:49 AM
#239
Posted 27 July 2012 - 03:47 PM
#240
Posted 27 July 2012 - 04:40 PM
