Last update for a while as the car is back at home for a bit while we get on with some work that pays the bills
Jobs left to do are:
Change 2 alloy water pipe angles for better access to various places
Finish the boot/engine cover which is nearly ready for testing then paint if all is ok
Make 2 side intakes like the turbo ones but probably a bit smaller
Fix an ABS wire that got broke by me
Fit an automatic choke soon as its back in stock
Make a new tail pipe (Current idea is to make it the same shape as the clam hole)
Tweak the suspension & fuel/ignition timing
Then hopefully a rolling road run to get the best from it and get ruff overall weight of the car from the local weigh bridge
Fingers crossed i,ll have something to update with next weekend but as it may be awhile till the next update i,ll leave you with a short test vid i done yesterday while moving it into the garage.
Bare in mind its a cold engine with no choke atmo but it gives an idea of what it will sound like
CLICK
Sam.
