Leak From Metal Bleed Screw
20 replies to this topic
#1 mrbodger
mrbodger
  • 336 posts
Posted 29 August 2010 - 07:09 PM
I've got a leak from the bleed screw on the top hose coming from my rad, I'm assuming the washer has perished, anyone got a part number for it? Done a search but can't find part number. Any help is much appreciated
#2 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,121 posts
Posted 29 August 2010 - 07:18 PM
no it's not a washer you need but a jubilee clip big enough to go round rubber surround (about 10mm from memory). Tighten it up and your leak will be no more. Regrettably it sounds a bit like your forum name but it does work.
#3 mrbodger
mrbodger
  • 336 posts
Posted 29 August 2010 - 07:22 PM
Nothing wrong with a bit of a bodge up, thanks Sutol.
#4 SteveM
SteveM
  • 1,608 posts
Posted 29 August 2010 - 10:41 PM
I have the same "fix" on mine with no problems. If you want the part get it from lotus instead of vxl, as it's half the price (about £60) for exactly the same part. How do vxl think they can get away with it? :beat:
#5 The Batman
Posted 29 August 2010 - 10:42 PM
if you get it from lotus then you have to replace both pipes as there bleed nipple is on the other side i think
#6 SteveM
SteveM
  • 1,608 posts
Posted 29 August 2010 - 10:44 PM
mine is behind the passenger headlight, as BoT repaired it for me whilst in for a service.
#7 The Batman
Posted 29 August 2010 - 10:46 PM
and thats a lotus one?
just get a eliseparts one the quality is awesome!
#8 SteveM
SteveM
  • 1,608 posts
Posted 29 August 2010 - 10:49 PM
so i'm informed, but the eliseparts one does look quality thumbsup
#9 Steve B
Steve B
  • 964 posts
  • Interests:Mountain Biking and Cars
Posted 30 August 2010 - 12:31 PM
I haveboth sides in silicon from Elise parts, it lasted aonth before it started weeping from the bleed nipple, the boss for the nipple turns in the silicon :(. Fixed it with a cable tie, not enough room for a jubliee clip on the ep one.
#10 The Batman
Posted 30 August 2010 - 12:33 PM
send it back, it will be covered by warranty thumbsup
#11 Guest_wivvy (Guest)
Guest_wivvy (Guest)
Posted 30 August 2010 - 01:27 PM
thumbsup for the jubilee clip from me too. Ive done a track day in mine too :) Who says you cant run a vx on a fiver :P
#12 Whiteboy
Whiteboy
  • 6,950 posts
Posted 30 August 2010 - 03:47 PM
Fab has done his with a jubilee clip and even with his run of bad luck it has held. thumbsup Steve
#13 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 30 August 2010 - 03:52 PM
Jubilee clip is a popular fix. I used the later style 'turbo' hose because I had it spare and the clam was off anyway and didn't want to risk needing to take it off again. Has the same plastic bleed screw as the heater hoses. Works fine so far.
#14 Steve B
Steve B
  • 964 posts
Posted 30 August 2010 - 04:54 PM
Cable tie works so can't really be bothered with the faffing about.
#15 A-GAME
A-GAME
  • 244 posts
Posted 30 January 2011 - 02:58 PM
anyone got a pic of this fix to the radiator bleed nipple to show where you cable tie/jubilee clip it? many thanks
#16 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 30 January 2011 - 03:57 PM
Sorry mate no picture But I had the same just have a look with the headlight removed and stick a clip or I used a cable tie about half way down the nipple that the bleed screw is in the end of Tighten it and you will probably find the bleed screw is now tight and dosent spin round
#17 A-GAME
A-GAME
  • 244 posts
Posted 06 February 2011 - 11:58 AM
cheers- any way i can get to it without removing the headlight?
#18 Sutol
Sutol
  • 8,121 posts
Posted 06 February 2011 - 12:02 PM
open the bonnet and look under the clam towards the H/light, you'll see the hose and the bleed nipple which will be on top.
#19 A-GAME
A-GAME
  • 244 posts
Posted 10 February 2011 - 11:56 PM
thanks. I had a look and found the screw would actually tighten up a full turn or so- might this sort it without the need for a cable tie. If I need to fit his does it just go around the rubber collar which has the bleed nipple on top of it? does it matter to which side of the screw you wrap it round?
#20 JG
JG
  • 13,612 posts
Posted 11 February 2011 - 09:51 AM
Another for the jublee and a little PTFE around the thread of the screw. Not a drip now.
